Advice on Indy quote for bushings!
Old Nov 13, 2013 | 06:12 AM
urboy4mbx's Avatar
Question Advice on Indy quote for bushings!
Hello,
straight to the point. I am getting charged $600 for the two front lower controller arms plus 3 hours labor which is about $300 in total $900
is this right? I've been looking at lower controller arms on ebay OEM, just to get an idea, and they are about $300 for both
I am not saying that this is what it should be, but can someone that has replaced this before tell me if it is worth almost 1k or should I look for another mechanic?
G35 2005 84k
Old Nov 13, 2013 | 09:31 AM
brazen's Avatar
It's a super easy DIY, so forget the mechanic, pick up some Raybestos lower control arms on rockauto.com for $50 each, and knock it all out for around $100 plus alignment.
I would steer clear of that mechanic in the future because that's insane. I can replace an LCA in my garage using just hand tools in 30 mins, and I'm no pro.
Old Nov 13, 2013 | 09:26 PM
urboy4mbx's Avatar
Yea. Thanks for the advice. Only thing is that doing it myself is not an option. I do not have the resources to do this (place to work on the car, tools etc).
I would rather have a mechanic work on it, but from what you are saying I can see that the price quote I received is a bit too much.
Old Nov 14, 2013 | 07:00 AM
brazen's Avatar
Alright, in that case just buy the control arms from Rock Auto, and find a shop that will install them. You should expect to be charged for 1 hour of labor total as it is a simple job with a lift and air tools (two bolts, a nut, and a castle nut on each side). If they're trying to charge for more time, I'd push back on it. You'll need an alignment afterward as well.
Good luck!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
6spdGspot
Oct 5, 2015 01:55 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
