6mt Problem on start
Old Dec 14, 2013 | 03:07 PM
OBscure's Avatar
I tried searching but maybe i was not typing in what is happening accurately. When i start the car in neutral and then let off the clutch the car will lurk forward a little bit. I am not sure why or how this is happening as the car is in neutral and i am only letting off the clutch. It does not move enough to hit a car in front of me if i am parked in a spot. But, should it be doing this? I have adjusted the clutch pedal down some if that may be doing it but i am not sure why it does this exactly. Thanks
Old Dec 14, 2013 | 03:09 PM
partyman66's Avatar
Does it only do it when it's extremely cold outside and the car has been sitting for a while?
Old Dec 14, 2013 | 03:14 PM
OBscure's Avatar
Yes I live in south Jersey so today it was mid 30s and it was the first time i started it all week and it did it.
Old Dec 14, 2013 | 03:48 PM
Texasscout's Avatar
I have never had that problem, but mine is a bitch to get in to first and second when it's really cold (relative term as I think 40F is cold), goes away after it gets the tranny good an warmed up. Does yours go away after it's warm?
Old Dec 14, 2013 | 03:52 PM
OBscure's Avatar
It only happens on cold starts and I also have a hard time getting in to second if i just start her up and take off. But if i give it time to sit and warm up a little then no problems. But the lurking only happens after the releasing the clutch (while out of gear) on a cold start.
Old Dec 14, 2013 | 05:55 PM
partyman66's Avatar
It's probably because the tranny fluid is so cold and viscous that the gears in the front half of the transmission are stirring up the gear oil and it's causing the rear half to move slightly with the fluid. This is a common occurrence in motorcycles as well.
Are you using factory gear oil in the tranny? My car doesn't do this, even when it's like 15 degrees out and I'm using OEM Nissan MTF. I've had this happen on other cars that were MT in the past though when running thicker fluid in the cold.
Old Dec 14, 2013 | 07:46 PM
OBscure's Avatar
I have not changed the gear oil since i bought the car a year ago. That may be why. Maybe over the winter i will change it and see if that works. thanks!
chinee
Jun 10, 2024 07:48 PM
andyg35c1
Aug 29, 2015 03:37 PM
derres
Aug 28, 2015 03:27 PM
NemesisGee
Aug 11, 2015 07:10 PM
chinee
Aug 8, 2015 10:11 AM
