VDC, ABS, Slip P-stuck problem
Hello guys!
I'm a guy from Sweden with a g35 07 coupe. I'm having a problem with my car and having a bad time figuring out whats wrong with my G, as the bad luck i already have somehow i can't find a place to fix my car here were i live in sweden because they'r not popular in here.(Thats weird) Would really appreciate all the help i can get! I'm not so good with cars but i love G's for sure! Anyway my problem is as you see what the title says my vdc, slip, abs lights are on. The car is stuck at parking. the light for the tire is on but thats because i changed to snow tires, they dont have tire pressure detector. The fan belt broke too i don't know if it has anything to do with this? After the fan belt broke i took it to a nissan dealer because i tought they would know but they had no clue i had to sent the car 80km to a mechanic that said he will try to fix the problem. After i left the car there they changed some fuses because they burnt out and they changed the fan belt. So i went there took my car 2 days later the lights pop-up again VDC,Slip and abs. I was afraid that something might go wrong again if i drive the car so i pressed the shift lock and drove home. A day later i took the car to a friend to change the fuses because i tought that might be the problem, he then took out the fuse and pushed it back in again, worked fine so he closed the hood and i was about to start the car again and drive home then the lights turnd on again. I've checked the brake fluid and its filled to the max. When i push the brake when turning on my car it makes a scratching sound.
One more thing, there is alot of snow here when the vdc kickes in it sound kinda high like a crack not sure if its supposed to sound like that?!
I've been checking around alot on the forum if someone is having the same problem but can't find someone with the similar problem. Really getting tired of this feeling so helpless when i can't turn my back to anyone with help, as i tought its full with g's owners here and someone might help me with more knowledge! Thanks in advance!
And sorry for the bad grammar english! By the way i've had the car for about a year and never had a singel problem with it before! Driven 59k miles!
Ill check them out but i think theyr all full !
Ill check that out to thanks!
Freeman186
Sep 6, 2023 10:07 AM
kevintandmd
Sep 3, 2015 06:41 PM
