When and how to get the G to it's potential
Old Feb 9, 2005 | 05:01 PM
tsolin01's Avatar
like with anything else shifting at redline everytime will take its toll on the engine sooner or later... if you're just cruising, i don't see the need to do that unless you really want to race someone... as for the MM mode, the 05 is pretty decent and it has the downshift revmatching thing where it'll blip the throttle a little when you downshift... once i installed the grounding wires, there does seem to be a better response in shifting, especially in double downshifting... the delay is still there but it doesn't seem that bad... seems comparable to a normal shift in a 6MT...
Old Feb 9, 2005 | 05:54 PM
KAHBOOM's Avatar
Oh just noticed that you have the 05.. Even Better!
Quite east to shift however you want with less effort in those. I wish the 05 program was available for 03's. My loaner was an 05.. It was a blast in MM mode.
The Z-tube gives you a deeper growl from the engine area at WOT.. It's intoxicating along with the exhaust note.
Old Feb 9, 2005 | 09:31 PM
dabarn1's Avatar
Dude get the HyperGround wires from STILLEN it will make the MM shifting hit the minute you tell it to shift. I installed them along with the STILLEN CAI and the Borla exhast, man talk about a seat of the pants differance. I can't stop picking races now.
Old Feb 9, 2005 | 10:25 PM
SilviaKs's Avatar
Originally Posted by pratik97
Well if you think the manumatic mode has too much of a delay, you haven't driven other manumatics then, mainly the BMW 3 series SMG. You hit the paddle and it'll shift about 2 seconds later. I know the M3 is a different story.
I found after test driving a lot that the G's manumatic mode was one of the best. Better than Mercedes, BMW.
SMG is a sequential gear box (similar to F1), totally different than a manuamatic.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Tyler's03G
Aug 13, 2015 10:04 AM
