Question about front upper control arm/ steering knuckle
Old Apr 9, 2014 | 10:12 PM
Adamg35-13's Avatar
I have a 2003 g coupe, I'm new to this whole thing and I was wanting to put some bigger wheels on. I was wondering if I go bigger wheel will I rub on my front upper control arm/ steering knuckle.
Attached Thumbnails Question about front upper control arm/ steering knuckle-image.jpg
Old Apr 9, 2014 | 10:23 PM
herrschaft's Avatar
How big of a wheel and tire are you talking about? Offset?
Old Apr 9, 2014 | 10:43 PM
Adamg35-13's Avatar
I was thinking
Old Apr 9, 2014 | 10:45 PM
Adamg35-13's Avatar
I was thinking bmw 7 series wheels. 19s ill look up the offset. 19x9 frot and 19x10 rear
Old Apr 9, 2014 | 10:49 PM
Adamg35-13's Avatar
24mm front and rear offset is what the specs say on them
Old Apr 9, 2014 | 10:57 PM
Adamg35-13's Avatar
I don't know what size tire I should get.
Old Apr 9, 2014 | 11:08 PM
Adamg35-13's Avatar
Sorry I forgot to tag you in these last descriptions.
Old Apr 9, 2014 | 11:24 PM
herrschaft's Avatar
A 19x9 with an offset below 35 will fit fine.
Old Apr 10, 2014 | 12:14 AM
Adamg35-13's Avatar
Thank you soooo much for your help. Here is the link of the wheel specs if you dont mind taking a look. http://m.ebay.com/itm/201070422632?cmd=VISPECI also just talked to a guy that has these on his g and he said he used a 25mm adapter. Does that sound right?
I will be buying new ones, this is just specs I found off of another set someone is selling.
Old Apr 10, 2014 | 06:16 AM
LoSt180's Avatar
He needed an adapter because the lug patterns are different between the BMW and Infiniti.
Old Apr 10, 2014 | 10:22 AM
Blue Dream's Avatar
I drove ttrank's car solo
If you get 25mm adapters the new offset will be -1 and you'll have to be very low and run a lot of negative camber to get those wheels to fit.
rezendvous420
May 31, 2020 01:26 PM
kd03g99
Jul 30, 2015 11:24 AM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
netcbc
Jul 24, 2015 01:59 PM
