Couple questions about the engine compartment from a noob
I've been reading, searching and looking at pictures but haven't found what I'm looking for.
2005 Sedan, 6MT
1. My windshield washer doesn't work. I can't find the washer container. I see a hose near the battery that connects to nothing. Possibly that should go to the bottle? Is the washer pump in the bottle or elsewhere?
2. I have seen lots of pictures of cars with covers over both the left and right side walled off compartments. Is this OEM or aftermarket?
2005 Sedan, 6MT
2005 Sedan, 6MT
2005 Sedan, 6MT
1: eh, not sure, I'd have to look under my hood.
2: its aftermarket. OEM has one over the battery, and the one covering the master cylinder is a modified battery cover. Just done to make it look more clean.
I'm fairly certain the sedans are the same but the windshield washer reservoir is directly below the passenger side headlight. Infiniti did not put covers over all of the compartments but you can buy those from the vendors on here.
Probably a cost cutting measure. You'd be surprised at how much they can save with something dumb like that when the savings is spread over a million+ cars.
i've been reading, searching and looking at pictures but haven't found what i'm looking for.
2005 sedan, 6mt
2. I have seen lots of pictures of cars with covers over both the left and right side walled off compartments. Is this oem or aftermarket?
2005 sedan, 6mt
2) After market.
All the newer g's come with a lid that says "brake fluid" instead of battery (which it is not)..i think this is what you were looking for.
joedaddy1
Jul 28, 2015 02:58 PM
