Door sensors not working
Old May 11, 2014 | 08:23 PM
Tylercr16's Avatar
I have a 2004 g35 coupe and today I noticed today that my dome lights (set to come on when doors are open) were on while I was driving. Also the indicator on the dash was showing a door was open. Next stop I check the doors and the were both closed. Also, when I apply the break, the dash light and dome lights go off, and the passenger window moves up slightly (as if you were shutting the door).
Any ideas?
I do have a double din radio set up with subs and we had a pretty bad rain storm today.
Old May 12, 2014 | 01:59 AM
hurleyguys's Avatar
there prob is a short somewhere in there. you will prob have to take it all apart to find and fix it.
Old May 12, 2014 | 05:10 AM
westsideblu's Avatar
Try unscrewing the door trigger switch and unplug it. Your car should think the door is closed with the switch unplugged. If you unplug it and the lights go off then that means the connection isnt disengaging when the door is shut so get a new switch. However if the lights dont go off when the switch is unplugged you have a wire somewhere touching metal as the door trigger is activated by the negative current (ground). If the passengers side window is rolling up when braking or whatever start with that door first.
tal1412
Nov 28, 2022 09:25 AM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
apintojr
Jul 23, 2015 10:52 AM
Jadenkid22
Jul 14, 2015 12:33 AM
