whistling noise from rear of car when coasting
Old May 11, 2014 | 10:43 PM
IkeepitG's Avatar
Angry whistling noise from rear of car when coasting
Hello all, im new to the forum so im not sure if this is the right place to be posting this, but ive been hearing this weird whistling/squealing noise from the rear end of my 05 g35 coupe. it seems to be coming from the back passenger side wheel. it only occurs when i let off the gas. when accelerating or braking it dissapears. what could this be ? ive only had the car from about 3 months and recently had the brake pads and rotors replaced due to loud squealing brakes. is this related to the problem im having ? Thanks in advance and i hope this was the right place to ask this question !
Old May 12, 2014 | 01:56 AM
hurleyguys's Avatar
hmm its kinda hard to diagnose without being in your car. try and get a video of the problem and then we can narrow it down more. it could be something as simple as something stuck to your car creating the whistle, or a bad door seal causing the whistle. or it could be your brakes, or a hundred other suspension components.
Old May 12, 2014 | 02:05 AM
ScraggleRock's Avatar
Mine has that same noise when I'm cruising at 74-76mph (which sucks cuz that's the Gs optimal cruising speed). 73 its not there, 77 its not there. It also disappears when I let off the gas. Its a common thing you just have to deal with. I don't think there's a fix yet.
Old May 12, 2014 | 07:44 AM
IkeepitG's Avatar
I'll try to get a video this afternoon. The noise occurs at any speed. Low speeds mainly.
rezendvous420
May 31, 2020 01:26 PM
Joshua615
Aug 31, 2015 12:29 AM
Kal Hamm
Jul 24, 2015 08:55 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
cyrus32
Jul 18, 2015 06:22 PM
