G35 overheating.. Cant find the problem
Old Jun 3, 2014 | 10:05 PM
Austin8868's Avatar
Originally Posted by coffeysm
Thanks!
Originally Posted by wuzz-upp
Here is a link to an excellent manual, I bought one to do the work on my 2003. The wiring schematics are descent good enough for troubleshooting.
http://www.ebay.com/itm/2004-Infinit...2499cf&vxp=mtr
I don't think there is a clutch, these are electric fans. They are either on or off, I could be wrong on this, I would have to research this further. In any case, RockAuto.com has a fan assembly for $100+shipping. Hope this helps.
He said he couldn't find a clutch but I could have read a couple different times on here that the 2004 has a fan clutch
Old Jun 3, 2014 | 10:10 PM
wuzz-upp's Avatar
Austin,
Section pg.pdf of the manual kindly provided by coffeysm, page 25 is what your mechanic will need.
Austin8868's Avatar
I found the "engine cooling system" section. Are there any others that you think would come in handy?
Old Jun 3, 2014 | 10:12 PM
Austin8868's Avatar
Austin,
Thanks. I will give him this one also .
Old Jun 3, 2014 | 10:33 PM
wuzz-upp's Avatar
Keep in mind that each fan motor receives 12V from a different source. One from fusible link H and the other from I, and there are three relays in the system. Good troubleshooting could save you unnecessary purchases.
Old Jun 3, 2014 | 10:54 PM
Austin8868's Avatar
Thanks for all the help. I have give him that info.
Old Jun 3, 2014 | 11:05 PM
Munish's Avatar
I have a overheating problem on my 2006 G35X. Just changed the thermostat and problem still exist.
Both fans working.any suggestions?
Old Jun 4, 2014 | 09:02 AM
LoSt180's Avatar
How many miles are on your G? This may be covered under WARRANTY!!! Why waste money?
Seriously, your mechanic confirmed one fan doesn't work.
https://g35driver.com/forums/g35-cou...an-motors.html
http://forums.nicoclub.com/04-06-rad...n-t467214.html
Edit, I'll even paste the letter here if you're too lazy to click a link:
Old Jun 4, 2014 | 10:19 AM
Austin8868's Avatar
It only has 68,000 miles but hasn't it passed the time period?
Old Jun 4, 2014 | 04:14 PM
NepTuneZ's Avatar
Man this sucks I too am having a issue with the over heating. Going to check the fans then relays to thermostat. My car starts up real hesitant and heavy does your car start that way too?
Old Jun 4, 2014 | 07:07 PM
wuzz-upp's Avatar
The math says 2012, 96/12=8, 2004+8=2012, but I would not hesitate to take it an and at least try and work something out. Maybe get them to troubleshoot it for free.
Old Jun 5, 2014 | 02:11 PM
Austin8868's Avatar
The car starts and runs fine I just can't run the AC.
I am going to replace the relays first then try a dealership if that doesn't work. The closest one is about 2 hours away.
Also which replay controls the backup lights? I need that replaced also.
Old Jun 5, 2014 | 09:26 PM
wuzz-upp's Avatar
Why are you going to replace the relays? Are they bad or are you guessing?
The backup lamp relay is E19, found on service manual section PG electrical units location.
Old Jun 5, 2014 | 09:39 PM
Austin8868's Avatar
changed the relays and now both the fans are coming on but the thing is still overheating. Guess I'm taking it to the dealership.
Old Jun 5, 2014 | 10:27 PM
  #30
wuzz-upp's Avatar
Austin,
Several questions:
1. Have you checked for proper anti-freeze level?
2. Have you checked for fluid circulation with the radiator cap off?
3. Have you checked for collapsed hoses which would restrict flow?
