parking brake adjustment
Old Jun 2, 2014 | 02:48 PM
Arthur Ch's Avatar
hi everyone, first time writing on the forum.
i have a 2005 g35 coupe rwd. my parking brake feels like its loose, every time i go over bumps i hear a clicking noise because the p brake is loose. anyone know how i can the p.brake? because when i push the p.brake a little bit and go over bumps the noise is gone.
do i need to change the brakes? or an adjustment is possible.
Old Jun 2, 2014 | 07:15 PM
BowWizzel's Avatar
Rear parking brake is adjustable. Once you remove the rotor there is a **** with notches like in the image below that is used to adjust tension on the brakes.
Old Jun 2, 2014 | 11:56 PM
Urbanengineer's Avatar
You just use a flat bladed screwdriver to twist it a certain direction. Your wheels should still spin freely when you have tightened them!
Old Jun 3, 2014 | 01:08 AM
BowWizzel's Avatar
Now that I think about it you can still adjust it with the rotor on. There's a rubber cap you just pop off and use a flathead to turn.
Old Jul 10, 2014 | 04:40 PM
Arthur Ch's Avatar
i already adjusted that to the max, if i adjust it any more the dist wont go in.
if you take your image as a reference the noise is coming from the loose spring holding the brakes together.
Old Jul 10, 2014 | 04:46 PM
BowWizzel's Avatar
You adjust it with the disk brake installed. The spring should not be loose.
Old Jul 11, 2014 | 12:03 AM
You might be going the wrong way.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Kicknshift
Sep 3, 2015 09:35 AM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
kinetek
Aug 3, 2015 04:25 PM
