Vdc light on abs light on slip light on all after new tires help
Old Jul 7, 2014 | 09:18 PM
jowca123's Avatar
Vdc
Slip
Abs
Lights are all on after about two minutes of driving I got new rear tires today and the problem occurred as soon after
I have Coilovers on the car and the new tires were rubbing fender so I figured raising it would solve the issue and then I did and the issues still persists
I've read all the forums on this issue and realize the possible problems but my brake fluid is perfectly fine and full along with my brake pads being fine
I just don't know why this would happen right after new tires
If you could respond quickly it would be much appreciated I am leaving for myrtle beach and going to put 1500 miles on my g tomorrow so please help me thank you if you could even text me with any pointers that would be great
440-334-4636 -jagger
Old Jul 7, 2014 | 10:48 PM
herrschaft's Avatar
What are the front and rear tire sizes?
Old Jul 7, 2014 | 10:54 PM
LoSt180's Avatar
Replace the front tires also, will fix your issue. The problem is that now your new rear tires are much taller than your worn down front tires. There's a ~3% stagger from the factory; old front tires with new rear tires pushes you out of that 3% tolerance.
Old Jul 8, 2014 | 12:13 PM
jowca123's Avatar
Ok that makes sense now but will raising my front coils a lot help that or will I have to change the tires to thicker ones like the rear ? Thank you by the way
Old Jul 8, 2014 | 01:17 PM
LoSt180's Avatar
The height of your car has no affect on your tire diameter. What size tires are on the car now?
Old Jul 19, 2014 | 12:09 PM
iREFRACT's Avatar
Just bought my coupe and it has the same lights on. Slip, Tire Pressure and VDC lights are on all the time. Yes the tires are aftermarket and I can understand why the tire pressure light would be triggered...but I don't see the between the slip and VDC lights/sensors. Any insight on this?
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
