O2 sensor confusion
Old Aug 8, 2014 | 01:11 PM
Urbanengineer's Avatar
Originally Posted by seymore4
What makes you say that?
This guy had that issue...
Old Aug 9, 2014 | 04:07 PM
acee's Avatar
Addict
Ok guys i just changed the sensors in my car upstream and downstream installed Oem cats as well n took off the test pipes reset the ECU and STILL STILLL STILLL STILLL GIVING ME THESE DAMN CODES P1168 P1148 P1031 P1051 LIKE WTH IS GOING ON MECHANIC TOLD ME IT CAN BE AN ELECTRICAL PROBLEM IDK THIS IS VERY FRUSTRATING AND MY DAD KEEPS TELLING ME JUST GO TO THE DEALERSHIP AND THEIR GONNA CHARGE ME AN EYE AND AN ARM , STILL TRYING FIGURE OUT WHATS GOING ON AnYone has any inputs and what am i doing wrong perhaps ????
Old Aug 10, 2014 | 10:05 AM
acee's Avatar
Addict
Bump anyone...
Old Aug 11, 2014 | 07:15 AM
acee's Avatar
Addict
Anyone help please :-( :-(
Old Aug 11, 2014 | 10:11 AM
LoSt180's Avatar
Did you clear the codes after you replaced the sensors?
Old Aug 11, 2014 | 10:23 AM
acee's Avatar
Addict
Yeah i did i did the pedal reset and the mechanic also tried to clear it with his obdii reader
???? Idk whats going on
Old Aug 11, 2014 | 10:34 AM
LoSt180's Avatar
Codes P1168, P1148 are for CLOSED LOOP CONTROL. Codes P0031, P0051 are for Sensor 1 Heater circuit. All codes you have listed are pointing to a problem with Sensor 1 (primary) on both sides.
If you've replaced them, then there may be a wiring issue that you'll need to chase down.
Here's some verbiage from the FSM to help you troubleshoot:
DTC P0031, P0032, P0051, P0052 A/F SENSOR 1 HEATER
P0031 - (Bank 1)
P0051 - (Bank 2)
Problem:
Air fuel ratio (A/F) sensor 1 heater control circuit low input
Condition:
The current amperage in the air fuel ratio (A/F) sensor 1 heater circuit is out of the normal range. (An excessively low voltage signal is sent to ECM through the air fuel ratio (A/F) sensor 1 heater.)
Possible Cause:
 * Harness or connectors (The A/F sensor 1 heater circuit is open or shorted.)
* Air Fuel ratio (A/F) sensor 1 heater
DTC P1148, P1168 CLOSED LOOP CONTROL
P1148 - (Bank 1)
P1168 - (Bank 2)
Problem:
Closed loop control function
Condition:
The closed loop control function does not operate even when vehicle is driving in the specified condition.
Possible Cause:
* Harness or connectors [The air fuel ratio (A/F) sensor 1 circuit is open or shorted.]
* Air fuel ratio (A/F) sensor 1
* Air fuel ratio (A/F) sensor 1 heater
NOTE: If DTC P1148 or P1168 is displayed with another DTC for air fuel ratio (A/F) sensor 1. Perform the trouble diagnosis for the corresponding DTC.
Old Aug 11, 2014 | 10:41 AM
LoSt180's Avatar
If you have a smartphone, I would HIGHLY advise you pick up a cheap bluetooth/wifi OBD2 dongle so that you can check and clear codes yourself without having to run to a mechanic all the time.
Old Aug 11, 2014 | 10:50 AM
acee's Avatar
Addict
Old Aug 11, 2014 | 10:54 AM
acee's Avatar
Addict
Sounds good i have an iphone 5 i can get this on the app store or something
Old Aug 12, 2014 | 11:49 AM
acee's Avatar
Addict
Problem is fixed guys something electrical or some type of voltage according to the electrical mechanic , he told me my ses light is off now i have to run the car 50-60 miles before my inspection. Im happy with the result.
Old Aug 12, 2014 | 01:43 PM
jookyshank's Avatar
I haz hugz to givez
Glad you got it fixed Acee...
Let's stay helpful and productive guys / gals...
danke!
Old Aug 12, 2014 | 01:57 PM
acee's Avatar
Addict
Originally Posted by jookyshank
Glad you got it fixed Acee... Let's stay helpful and productive guys / gals... danke!
Thank u man, sorry to everyone but i shouldve just ignored it... Just a simple guy asking for help n to get my knowledge up...appreciate everyone else who helped me.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
Rose M
Oct 12, 2015 10:00 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
