04 G35 coupe start up issue.
Old Aug 20, 2014 | 05:57 PM
cyt_411's Avatar
Hello forum, I have a 2004 g35 coupe with about 48,000 miles on it. I disconnected the battery and hooked it up to a charger and let it charge for 6 hours. After charging of the battery is completed, I reconnected the battery to the car and started up fine. What I notice is that after turning the car off and starting it back up again it has a hard time starting. The car would start then as soon and I turn the key to the on position the RPM would drop and then stall. I would have to give the car some gas to prevent the vehicle from stalling. My question is what could be the cause of this issue. And has anyone have this issue? Thank you in advanced.
Old Aug 20, 2014 | 06:42 PM
coffeysm's Avatar
Does it do this everytime or just when you start, stop, and try to restart it? I'd start with the basics: fuel, air, and spark. Since, you have to press the gas maybe an injector is dirty or the fuel pump is iffy. Do you have any CEL?
Old Aug 20, 2014 | 10:05 PM
cyt_411's Avatar
Before the battery was removed it didn't have this issue. Now its doing it about every time. There's is no check engine light displayed and replaced the plugs around 30k miles. Could this be do to the fact that i've removed the battery and the ECU has to relearn everything again?
Old Aug 20, 2014 | 10:12 PM
coffeysm's Avatar
Nah, I don't think that should have anything to do with the ECU learning everything again. I'd double check your positive and negative connections. Do you have a multimeter to check the battery voltage?
Old Aug 20, 2014 | 10:27 PM
ScraggleRock's Avatar
If it starts fine cold, but not when its already warm its a dirty throttle body. EGR gasses muck up the hinges on the butterfly and just need to be cleaned off.
Old Aug 20, 2014 | 10:51 PM
cyt_411's Avatar
this video show the exact problem, starts up and stalls.
as Gdirtyfive55 says the throttle body needs to be cleaned. Does anyone know the proper way of cleaning it? I've never done anything like with electronic throttle body before.
Old Aug 20, 2014 | 11:14 PM
gary c's Avatar
Needs ECU reset, no issues before disconnecting the battery!
In his own thread he admits disconnecting the battery for six hours, the ECU forgot why it's there and what it's job is. By doing a reset, that should correct all your ills. Our battery's shouldn't be disconnected for more than an hour or two maximum...Gary
Old Aug 20, 2014 | 11:24 PM
https://g35driver.com/forums/showthr...548&styleid=51
Old Aug 21, 2014 | 01:21 AM
coffeysm's Avatar
I guess you can try these steps before trying to clean the throttle body:
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Old Aug 21, 2014 | 01:42 AM
*sigh*
Just clean the tb
Old Aug 21, 2014 | 06:54 AM
rsingerG35's Avatar
I doubt his ecu forgot why its there. My G went without having power for days and worked fine when I put a new battery in.
Old Aug 21, 2014 | 08:02 AM
BAAG35's Avatar
I never understood this logic.
Both of my vehicle's batteries are disconnected before going into long term storage each year without any issues.
Please explain how an inanimate object can "forget".
Old Aug 21, 2014 | 08:20 AM
partyman66's Avatar
Not sure why you say that. It's pretty common to disconnect a battery from cars or other vehicles in general for storage reasons for way longer time periods than just a few hours. I do it every year in my G and all of my motorcycles for 3-4 months. They all work fine in the spring when I reinstall them as long as I have them on a trickle charger in the winter and stored in a climate controlled environment. Mechanics regular do this too while doing big repair jobs on a car.
Old Aug 21, 2014 | 10:49 AM
gary c's Avatar
Before I got my Osiris tune I was throwing a lean condition warning and decided to disconnect my battery over night. Next morning start up took a while and idle was below 300 rpm cold, my coupe was a mess. Went to Nissan where a friend worked, being trained in everything Nissan makes including the GT-R I believed what he told me. "Removing the negative side of the battery for several hours will make your ECU forget why it's there!" That is what happened to me, the fix didn't include cleaning my TB!
Gary
Old Aug 22, 2014 | 01:27 AM
partyman66's Avatar
Gary
Well you just said yourself that your car was not running right before you disconnected the battery.... Disconnecting the battery overnight didn't make your problem, it just transformed the symptoms of an existing problem.
I think your mechanic buddy was just being facetious when he said that. Leaving it disconnected in our cars for a long enough period of time will cause it to lose any learned tuning parameters, but the ECU is just a computer with firmware running on it like any other computer, router or network appliance. If it loses that learned data due to prolonged power failure causing a RAM wipe, it just reverts back to the firmware's locked default values and will attempt to relearn them again from there.
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
NemesisGee
Aug 11, 2015 07:10 PM
