labor per hour?
Old Feb 14, 2005 | 11:42 PM
Vic's Avatar
Vic
labor per hour?
Just want to know how much would people normally charge to install exhaust? is $80/hour expensive?
Old Feb 14, 2005 | 11:43 PM
ChazM's Avatar
I think that is a normal price for a dealer, actually how long should it take to install an exhaust...an hour?
Old Feb 15, 2005 | 12:53 AM
Vic's Avatar
Vic
I'm not sure.. by the way, i'm not installing the exhaust in a dealer. I'm installing it at my friend's performance shop. so, what is the typical labor cost per hour in a performance shop?
Old Feb 15, 2005 | 01:50 AM
kenchan's Avatar
Really depends on the shop. Ive seen shops charge anywhere from $55 to $100
per hour most falling around $85/hour.
Installing exhaust is not hard to do...you should get someone to help you
install it yourself.
Old Feb 15, 2005 | 02:51 AM
g35sammy's Avatar
so shops no matter what they are working on charges the same amount for labor. whether it be front lip, tires, sways, short shifter? correct?
Old Feb 15, 2005 | 01:44 PM
kenchan's Avatar
Yah, pretty much unless they need special equipment to do the work...
but the parts you listed, should be the same.
Old Feb 15, 2005 | 05:31 PM
G35_coupe_6MT's Avatar
Melbourne's delaer wants to charge me 200$ for a 1 hour job! Its just running a cable from fuse box through the a-pillar and drilling a small hole on the roof for a speed detector to be hooked up there. NO FUKING WAY! I went to another place and they quoted me 50$ and I had to ask again because I couldnt believe hearing 50 after hearing 200.
Old Feb 15, 2005 | 06:27 PM
SkylineG33's Avatar
Yeah...$50 labor is about right for exhaust, that's what my buddy charges for his service.
Old Feb 15, 2005 | 06:42 PM
sen_jen's Avatar
Meatshake Enterprise
anywhere from $50- $???. it depends if it's a custom setup. if it's just a bolt on exhaust system (e.g. injen, stillen, fujitsubo+ypipe, greddy, etc), then it shouldn't exceed $80.
jeffbdye
Jun 1, 2018 03:51 PM
Learned Hand
Oct 1, 2015 09:02 AM
