G35 Shocks/Struts. Need some advice!
Old 11-09-2014, 10:43 PM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
Originally Posted by Gdirtyfive55
They are hard to replace if you don't have the right tools. I doubt they're worn out. Its unnecessary unless you're upgrading to polyurethane.
Poly bushings are a good idea but you don't ever want to install them in a-arms or where movement is required! In less than two years they'll start making more noise than the human brain can tolerate! I did one of our Vettes in 100% polyurethane thinking it would make for a tight/solid ride with new shocks...it did! Now the issues is no one makes rubber bushings for this model/year, until they do we're stuck with awful noise and constantly spraying the a-arms with silicone spray...Gary
Old 11-09-2014, 10:52 PM
gmmills's Avatar
We have 4 shocks.
I thought 2 struts and 2 shocks?
Old 11-10-2014, 02:25 AM
ScraggleRock's Avatar
No. Struts affect alignment angles and are a pivot point on steering. Like my buddies MS3, the camber plates are the strut mounts. Our multi link suspension uses shocks strictly for dampening. They serve no other purpose.
gmmills (11-10-2014)
Old 11-10-2014, 04:26 PM
Mustang5L5's Avatar
Sorta....
A strut is a structural part of the vehicle's suspension, where a shock is not.
So while the suspenson does not use the front strut for suspension geometry, it does hold the spring. If you remove the strut from the front, you can't drive the car because it will just lay on the ground. So considering the front component does take the weight of the vehicle and "suspends" it on the spring, it's a strut.
A shock you can remove and actually drive the car around (although not recommended). So you can remove your rear shocks and still drive the car around the block.
I'm installing the KYB's on my sedan. Still on the original suspension at 150K miles other than both compression rods. I regularly inspect and my bushings are fine, but I think it's time to replace the struts/shocks
Old 11-10-2014, 04:36 PM
Originally Posted by Mustang5L5
Sorta....
Almost no multi link suspension uses struts. I'm fairly certain ours are considered shocks. If you look up parts, every parts place (so long as its not "Franks Auto Store") that I've looked at lists them as shocks.
http://www.shockwarehouse.com/site/p...nd-Nissan-350Z
Old 11-10-2014, 05:54 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
Originally Posted by the93owner
I have the Tokico HP ("Blue") shocks and they have a very good feel. Make sure you talk to Charles at B2AutoDesigns (a vendor here), he is very knowledgable and offers great pricing and service. I believe a set of 4 brand new is $350 shipped (but don't take my word for it)
It's my understanding that the Tokico HP (blue) are the closest thing to stock that you can get on the aftermarket. I have the d-specs and I love them. With a 1" drop, hotchkis sway bars and the d-specs, my car really handles well.
Old 11-13-2014, 02:06 PM
TheBay's Avatar
So wait do the Tokico D-SPECS drop the car? I ask because I was thinking about dropping my car with coil overs but I have decided to go with the Tokico HP Shocks and spending the extra 700 I would save on a clutch.
Although, if Tokico D-Specs lower the car I would look into purchasing those.
Old 11-13-2014, 02:10 PM
Texasscout's Avatar
No, d-specs do not lower, they are not like coil overs. The just replace the original shocks. You would still need lowering springs with them.
netcbc
Exterior - Body Parts CDN
08-21-2015 09:50 AM
DRG35R
07-31-2015 10:23 AM
VANST3R
Lights
07-27-2015 08:20 PM
laksjd84
07-24-2015 05:12 PM
CrazyLogic219
07-23-2015 10:58 AM
Quick Reply: G35 Shocks/Struts. Need some advice!
