Abs/Slip/VDC ALL on :(
Old Nov 15, 2014 | 08:56 PM
Lartytiejdke3's Avatar
Guys I need your help. We were tucking the remaining side headlight harness (driver side)
Put everything back as it was except obviously tucked. All sensors and clips are tight.
Except the lights are all on in the gauges.brake fluid checks out as well. Car runs and pulls normally. Tried resetting the Ecu Unplugging the battery and pumping the brakes. Nothing
Anything?
Old Nov 15, 2014 | 09:43 PM
Frankieg35's Avatar
Try keeping the battery unplugged over night..
Old Nov 15, 2014 | 10:31 PM
Urbanengineer's Avatar
Hey you were there help him out! Time for a fuse check.
Old Nov 15, 2014 | 10:32 PM
Yeah I'll go do that before I fall asleep
Old Nov 17, 2014 | 06:17 AM
HenryLee's Avatar
Low brake fluid or pads?
Old Nov 17, 2014 | 06:22 AM
nope those all check out ok
Old Nov 17, 2014 | 02:42 PM
DragonBoas's Avatar
look up abs reset procedure and try that. I got that same stuff when pulled the interior out to run wires under the carpet and I knocked the abs unit and i guess that was enough to set those lights off. Everything seemed to run normal but the lights are obnoxious.
Old Nov 18, 2014 | 08:51 PM
yeah I'm checkin that soon
Thanks man
I'll report back
Old Nov 22, 2014 | 03:18 PM
where are you finding this reset procedure? cant find it in any searches
Old Nov 23, 2014 | 06:30 PM
Now I got a p1065 code
What do?
Old Nov 23, 2014 | 08:58 PM
ScraggleRock's Avatar
Did yer ECM get unplugged messing with it or something?
Old Nov 23, 2014 | 10:01 PM
where would that be located exactly
Old Nov 23, 2014 | 10:02 PM
Can't believe you're fagglerock now Dirty
Wtf man wtf
Old Nov 23, 2014 | 10:20 PM
Calm down, brah. I couldn't deal with all the other dirty fives. Then when I realized how "bro" it sounded, it was over. My name actually came from making fun of my friends brothers speach impediment, not from being some bromosexual. It was from making fun of children.
Anyway, that code is an open circuit on the ecm or faulty ecm. How many times have you reset it?
Old Nov 23, 2014 | 10:58 PM
Calm down, brah. I couldn't deal with all the other dirty fives. Then when I realized how "bro" it sounded, it was over. My name actually came from making fun of my friends brothers speach impediment, not from being some bromosexual. It was from making fun of children. Anyway, that code is an open circuit on the ecm or faulty ecm. How many times have you reset it?
You'll always be my Dirty
times I reset it before or after I threw the code?
I reset it with the pedal reset and now it's gone but I'm wondering if it's setting off the other lights
