tire pressure?
Old Feb 17, 2005 | 02:17 PM
coolnesh's Avatar
tire pressure?
what tire pressure do you guys use?? Front and Back.
also mention the tire size.
Old Feb 17, 2005 | 02:25 PM
cungkpham's Avatar
i just use 35 all way around on 18's.. works for me
Old Feb 17, 2005 | 04:15 PM
Brewin98's Avatar
I also use 35 all around on 17s. California weather. The interesting thing is that when I picked it up from the dealer they were at about 43. Others have had similar experiences.
Old Feb 17, 2005 | 04:20 PM
kenchan's Avatar
35 in factory 18's during the summer.
I use 38 in the winter as my car sits in the garage more than is driven
(snow season). The dealer recently also pumped 38psi after my recent oil change.
maxpower's Avatar
35 psi front and rear 19's
Old Feb 17, 2005 | 04:21 PM
robbdogg's Avatar
35 all around on 19's
Old Feb 17, 2005 | 06:12 PM
jayco's Avatar
35psi all around on stock 18s
Old Feb 17, 2005 | 06:52 PM
Z2G's Avatar
Z2G
Jose
if you have the 17's, that's way too high. it should be at 30-32 psi. after a bit of time, you will notice that the center of the tires will wear much more than the outside treads. check out the information sticker on the driver side door sill. after my first experience with the 17's on my 03 coupe, i started to leave it at about 1 psi under the recommended pressures. i noticed more even wear from that point on.
Old Feb 17, 2005 | 07:01 PM
shipsaeki's Avatar
I use 34-36 PSI depending on what the weather is like.
And the reason some cars come with so much PSI in the tires, is b/c the tech who prepped the car, didn't adjust the tire pressure.
When I prep cars, you have to adjust the psi b/c they come factory with around 42-44 psi.
Old Feb 17, 2005 | 09:04 PM
DrPJM1's Avatar
32psi cold
Old Feb 17, 2005 | 09:36 PM
dave's Avatar
I use 35 in the 18s (summer), and 30 in the 17s (winter)
Old Feb 17, 2005 | 09:37 PM
gto2050's Avatar
40 on 18"'s.... ever since driving school i have used this much pressure. Makes it corner like a demon and doesn't really destroy the ride. BTW...I have NEVER seen tires wear out from over inflation...
Old Feb 18, 2005 | 10:38 AM
coolnesh's Avatar
I have 17s on my audi... and I use 34 or 36 all around depending. The ride quality changes quite a bit (for the better) when I use 36.
Old Feb 18, 2005 | 11:07 AM
DiamondGCoupe's Avatar
Stock 18's, 35psi all around.
Old Feb 19, 2005 | 02:36 AM
Brewin98's Avatar
Thanks for the heads up on the 17s psi. I am upgrading to the 19's this weekend.
