Need tune up advice
Old Feb 28, 2015 | 10:55 AM
Siciliang35's Avatar
Need tune up advice
What do you guys change on these cars for maintenance ? Plugs , air and gas filter, what else on a 03? What brands and also on the intake spacers what size gives the best performance?
Old Feb 28, 2015 | 11:31 AM
Texasscout's Avatar
Plugs, fuel filter, air filter is about all you can do. As for a spacer, the 5/16" seems to offer the best gains, even over the 1/2". Don't bother with a Cold Air intake, no gains to be had, just noise. Best bet is find a "Rev-Up" air box (2005-2007) with the built in "velocity stack". You can prob find one cheap on CL or in the classifieds here.
Tex
Old Feb 28, 2015 | 01:16 PM
Yeah i figured thats all i can do. Is there any sensors i should start changing ? I have 120 k miles
Old Mar 1, 2015 | 09:43 AM
Texasscout's Avatar
I wouldn't think so, just the O2 if it's throwing the proper code for it. If you run good gas, like I do, I have 130K with only one CEL and that was for a temp sensor in the gas tank.
Old Mar 1, 2015 | 10:57 AM
gary c's Avatar
Tex, fuel filter isn't changed unless there's a pump failure, she's in the tank!
Motordyne's 5/16" spacer is the most popular. Installing the 1/2" you lose the ability to use the engine cover and the hp comes in at higher rpm. Nissan's maintenance schedule or tune up as you called it is all fluids/filters every 30K miles and plugs at 100K miles. I suggest replacing belts at the interval too and plugs more frequently...Gary
Old Mar 1, 2015 | 11:36 PM
Texasscout's Avatar
Yeah, I forgot about that. I change my brake fluid every year. trans at 60-70K along with the diff. Never changed the power steering fluid, I need to do that. Belts AND hoses. I did that at 75K.
Old Mar 2, 2015 | 01:16 AM
Urbanengineer's Avatar
Every 2 years is fine...
Old Mar 2, 2015 | 09:59 AM
Texasscout's Avatar
Yeah, I know, but participation in the Raging Bull Texas Stampede requires it.
Old Mar 2, 2015 | 10:45 AM
gary c's Avatar
Tex, how often have you changed your fuel filter?
Gary
Old Mar 2, 2015 | 10:49 AM
Texasscout's Avatar
Gary
Never, if it's in the tank, it's nothing more than a SS screen and really doesn't need changing.
Old Mar 2, 2015 | 11:23 AM
gary c's Avatar
Tex
We knew that but this is what you posted.
Gary
Old Mar 2, 2015 | 11:32 AM
Texasscout's Avatar
Yeah, I didn't know it was in the tank, so...
I do believe YOU were a little green at this at one time also:
https://g35driver.com/forums/g35-cou...ml#post3717027
Old Mar 2, 2015 | 07:32 PM
gary c's Avatar
Tex, I only knew the answer because I asked the question 11 months ago! Knowing it wasn't under the hood, couldn't find the answer using our Search. I made a thread asking where the fuel filter was hidden.
Gary
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
