First problems
Old Mar 25, 2015 | 05:37 PM
djtalon's Avatar
Originally Posted by G35Rican
Does your A/C get hot if sitting at a light as well until you start going again??
So I brought it to the dealer. They found a fuse relay that was busted. Fixed that and they both work well now. The two fans should turn on at the same time. No more problems.
Old Mar 25, 2015 | 06:58 PM
G35Rican's Avatar
do you have the part# that they replaced so I can check mine out. I had a small leak in the smaller coolant hoses, replaced them and was doing fine, till I sat in the parking lot today with the a/c on. I'm pretty sure the passenger fan helps cool the car when its sitting as no overheats when cruising.
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
