Misfire Cyl 1
Old Mar 12, 2015 | 11:16 AM
sabino787's Avatar
Originally Posted by maxxcool
Excellent... has cylinder 2,4,6 ever miss-fired ? if not I lean very heavily towards the passenger side Cam sensor being your issue.
They have never misfired. The misfire started at cyl 1, changed the spark and coil and the misfire movrd to cyl 3
Old Mar 12, 2015 | 12:43 PM
maxxcool's Avatar
Same brand plugs and coil? or new brand when you swapped ? .. hmmm
I know a cracked ceramic has been a issue in the maxima forums before. Did you or someone (prior owner) change the heat rating on the plugs ?
I'd swap coil and plug on 1 to 3 and see if 1 magically starts tossing codes again if the plugs are different heat ratings. could also be a ping\knock issue. possibly from heat, or from the mixture being to lean.
hmmm ...
edit typo.
Old Mar 12, 2015 | 02:28 PM
sabino787's Avatar
hmmm ...
edit typo.
I installed an afternarket coil from autozone and the same brand spark plug (4469) ngk iridium. What confuses me is that now the misfire is on cyl 3 and not 1. Should I replace all the coils and plugs..?
Old Mar 12, 2015 | 03:02 PM
maxxcool's Avatar
And that could be the clue... or a coincidence. if the engine is having some mixture issues (because of the bad fuel burn?) the old plugs could be causing the missfire as a combination of the less than optimal fuel ratio + temp/hot or old plugs + the tendency to ping in the 2nd gen vq35de naturally.
since the expensive plugs are 12$ and the oems\direct replacements are 9$ i'd finish off replacing the whole passenger bank, 3,5... that would be my 2c. its cheaper than the cam-sensor so in a progressive troubleshoot of going inexpensive 1st that would be the 1st step.
*IF* you are adventurous .. and you have noticed or know you have mid-rpm engine ping you might consider going 1 step colder. helped me in my 2006-sedan.. but that's just my personal experience.
Old Mar 12, 2015 | 03:08 PM
maxxcool's Avatar
After that things get spendy. replacing two more CoP's is what a 100$ ? hmmm I do not know how you'd test this but I would test the output on the remaining two Cop's..
barring testing the Cop's I lean back towards the Cam sensor as a culprit.
Old Mar 12, 2015 | 03:16 PM
maxxcool's Avatar
i have seen a few Nissam maxima threads on the MaF being a cause. (incorrect mixure result)... maf's are cheaper than CoP's (but a pain to reset)..
just a random thought..
Old Mar 12, 2015 | 06:21 PM
sabino787's Avatar
I got news... I just got home, changed coil 5 to cylinder 3 and coil 3 to cylinder 5. Started car. Everythings works perfect. (I did clean the coil a little)
Should i use the car like this?
Old Mar 12, 2015 | 10:51 PM
maxxcool's Avatar
I do not see why not, if it was a contact issue you may have fixed it with the cleaning and or re-seating the CoP. Id say drive it and see if it pops the cel light
Old Mar 13, 2015 | 04:58 AM
partyman66's Avatar
Yep... shouldn't cause any problems. I suspect the problem will return within a few days, probably on a different cylinder.
Question.... on the days that it misfires, what was the weather like? Was it rainy or excessively humid and damp? Did you use Dielectric grease on the plug boots?
Old Mar 13, 2015 | 10:42 AM
maxxcool's Avatar
mmm yummy conductive grease always a good add.
Old Mar 15, 2015 | 01:12 AM
sabino787's Avatar
Cool
It was "Puerto Rico's weather" hot. 93 degrees during day around 65 at night.
I didn't use conductive grease, but if the problem comes back I will try that.
I just installed the 5/16 motordyne spacer today and the car runs excellent. ( of course better from 3500rpm above!)
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
KallDay86
Jan 8, 2016 12:42 AM
vamarris
Sep 26, 2015 12:56 PM
ghost_g35
Aug 7, 2015 10:31 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
