VDC,Slip and Abs
Old Mar 23, 2015 | 11:10 PM
6SJ's Avatar
6SJ
VDC,Slip and Abs
Lights Came on after I knocked my wheel on a curb and now it ramdomly goes on and off, I just got my brake pads replaced on my brembos <3 andvit kinda the opposite it drives fine when the abs, slip and VDC lights are on, the lights go away as if the problem is gone and my brakes make a really bad noise i turn the car off and the VDC slip and abs lights come on and the brakes go back to normal? Any ideas what tf this could be and someone tell me where I can get my lights reset or if it's a wheel sensor that needs to be replaced?
Old Mar 24, 2015 | 11:09 AM
Mustang5L5's Avatar
Well, if the problem started after knocking a curb with your wheel, i'd venture to guess that it's possibly related. I would start by pulling the wheel off and having a peek around.
I would also check to see if a wheel sensor was damaged during the recent brake job.
Old Mar 24, 2015 | 02:50 PM
LoSt180's Avatar
How hard was the curb impact? There's a TSB about wheel bearings being bad after an accident that impacts the wheels. If the impact was in the front, then it's certainly possible the ABS sensor, or tone ring on the bearing is damaged.
Old Mar 25, 2015 | 01:01 PM
mdl66's Avatar
Sometimes, those lights come on if the brake fluid level is low.Possibly check that as well as checking for other damage resulting from the curb knock.
Old Mar 27, 2015 | 06:45 PM
thepro78's Avatar
Check your Alignment too!!!
Those 3 lights will turn on when it get out of the spec Alignment... like when u hit the curb.....
hope that nothing is broken down there.
Old Mar 27, 2015 | 10:12 PM
Gorhad's Avatar
I had same issue mine was steering angle sensor get an alignment and get the shop to reset the sensor
Old Mar 30, 2015 | 11:01 AM
ILCruisin2006's Avatar
My slip and vdc off lights came on ages ago. I think mine has something to do with brake wear. I believe I read something about the lights staying on if the brakes were too worn.
Old Mar 30, 2015 | 12:04 PM
Mustang5L5's Avatar
ONLY the red BRAKE light has any indicator on brake wear and that's just from the brake fluid level dropping down low enough to trigger the sensor
Old Mar 30, 2015 | 01:33 PM
Lartytiejdke3's Avatar
Speed sensor malfunctions can trigger this also correct?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
