Art Pipes Question
Old Mar 31, 2015 | 03:17 AM
erickLA's Avatar
Art Pipes Question
So today I purchased some Art Pipes to pair up with my stock exhaust. I have a couple of friends that say once I install the Art Pipes, my G will run lean? Is this true & will I need a tune right afterwards then? The only engine mods I have is a Z-Tube with a K&N drop-in filter. I want to install full bolt ons before I get a tune but want to know if it's necessary to get one when I install the pipes. I don't want to re-tune it and spend more money if it's not needed. Any help is appreciated.
Old Mar 31, 2015 | 08:48 AM
rramos3's Avatar
I wouldn't worry about it until you start going full boltons. even then its not necessary, but recommended. not sure if the ART pipes throw a CEL, that would be a reason to.
I would bet others here will agree with more detail.
Old Mar 31, 2015 | 11:04 AM
erickLA's Avatar
Originally Posted by rramos3
I wouldn't worry about it until you start going full boltons. even then its not necessary, but recommended. not sure if the ART pipes throw a CEL, that would be a reason to. I would bet others here will agree with more detail.
Isn't it bad if I run it lean though? I've talked to Tony over at Motordyne and he said that it shouldn't throw a code. Hoping others will chime in with more detail. Really want to know because ill be getting them tomorrow and hopefully installing them by Friday.
Old Mar 31, 2015 | 11:15 AM
Spartan268's Avatar
The CEL shouldnt come on.
And you wont be running lean to the point where you're killing yourself, but you will lean yourself out a bit more. Get on the full exhaust asap then tune her up. If you have no plans for an exhaust, then get the tune now.
Old Mar 31, 2015 | 11:19 AM
erickLA's Avatar
Originally Posted by Spartan268
The CEL shouldnt come on. And you wont be running lean to the point where you're killing yourself, but you will lean yourself out a bit more. Get on the full exhaust asap then tune her up. If you have no plans for an exhaust, then get the tune now.
Do you still recommend tuning it after the installation of the art pipes? Even though I still want to other bolt ons? I plan on not adding an exhaust at the moment. I'll probably stick around with the stock for awhile but may be adding a XYZ pipe with resonator depending on how bad the rasp is.
Old Mar 31, 2015 | 12:02 PM
Spartan268's Avatar
My general opinion on tunes is to get it done after all the bolt ons to save money. No point re-tuning after each mod. For now, stick with the ARTs without tune and confirm whether or not you'll get the XYZ. And then base your decision on that.
If you're worried about blowing something up, nothings gonna happen. Some people rolled around here with full-bolt ons for a long while before tuning (Such as a buddy of mine).
EDIT: I also noticed you dont have a spacer yet. GET ON THAT ASAP!
Old Mar 31, 2015 | 12:16 PM
erickLA's Avatar
My general opinion on tunes is to get it done after all the bolt ons to save money. No point re-tuning after each mod. For now, stick with the ARTs without tune and confirm whether or not you'll get the XYZ. And then base your decision on that. If you're worried about blowing something up, nothings gonna happen. Some people rolled around here with full-bolt ons for a long while before tuning (Such as a buddy of mine). EDIT: I also noticed you dont have a spacer yet. GET ON THAT ASAP!
Yeah that's what I was worried about. Blowing something up. Lol. But I'm still not sure on the XYZ pipe because like I said, it depends on how the rasp gets to me. If it's not bad, then I probably won't buy it. But I'm saving up for the spacer now. What do you recommend? The 1/2 or the 5/16? From what I read, I'd go with the 5/16 but still not sure. So I can run with the bolt ons for a while then right? Tunes are expensive so It'll be awhile before I would be able to get it done. But I'm for sure getting it tuned.
Old Mar 31, 2015 | 12:25 PM
Spartan268's Avatar
There should be a video or 2 with people with the same stock setup + ARTs. It'll give you an idea of what to expect, but videos never do justice since headphones and microphones arent too capable of catching the full sound range.
Personally I would recommend the 5/16th since it provides more usable power (midrange) vs the gains of the 1/2 which is more on the upper end. If you live life on the redline the 1/2 will be your choice. If not, 5/16 it is.
Old Mar 31, 2015 | 12:56 PM
erickLA's Avatar
There should be a video or 2 with people with the same stock setup + ARTs. It'll give you an idea of what to expect, but videos never do justice since headphones and microphones arent too capable of catching the full sound range. Personally I would recommend the 5/16th since it provides more usable power (midrange) vs the gains of the 1/2 which is more on the upper end. If you live life on the redline the 1/2 will be your choice. If not, 5/16 it is.
Yea I've seen a few videos already and as you said, videos do no justice. But I might have enough for the spacer so I might buy it this week. Is it easy to install? Is there a diy for it? And that's all I really need right before I get a tune right? My G is 5AT. I have a z-tube, K&N drop in filter, art pipes which I will be receiving tomorrow and the plenum spacer when I do purchase it.
Old Mar 31, 2015 | 03:02 PM
PhoenixG35's Avatar
Your setup as is will be quite raspy. I wouldn't get a tune until you at least purchase a plenum spacer and catback exhaust (true dual preferred).
I've been on full boltons since last August, car is leaned out I am sure but then again I have only floored it once since then (after my ART pipes install) and during my daily driving never take it above 4k rpm or 75% throttle position. Just stay off the wide open throttle pulls until you tune.
Old Mar 31, 2015 | 04:57 PM
erickLA's Avatar
Originally Posted by PhoenixG35
Your setup as is will be quite raspy. I wouldn't get a tune until you at least purchase a plenum spacer and catback exhaust (true dual preferred). I've been on full boltons since last August, car is leaned out I am sure but then again I have only floored it once since then (after my ART pipes install) and during my daily driving never take it above 4k rpm or 75% throttle position. Just stay off the wide open throttle pulls until you tune.
I purchased the plenum spacer about an hour ago. As for the exhaust Catback system, I probably won't get it till around summer time. Should i wait to get a tune once I do get an exhaust? I floor it every once and a while. I don't do it as much
Old Apr 1, 2015 | 12:03 AM
PhoenixG35's Avatar
yes and try not to floor it... sucks but healthy engine is better than headaches down the road
Old Apr 2, 2015 | 01:45 PM
zcherub's Avatar
You should be fine. Worry about blowing something up when you're running forced induction or NOS. A slightly wider pipe in your exhaust shouldn't make anything explode!
Old Apr 3, 2015 | 02:07 PM
erickLA's Avatar
Thank you! I'm not worried as much now, I'll be installing them this weekend or next week. Hope everything runs fine.
Spartan268
Aug 20, 2015 09:14 PM
G35Papa
Engine - Exhaust
Aug 18, 2015 11:39 AM
IkonG35
Aug 10, 2015 09:33 AM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
