Shifting
Old Apr 6, 2015 | 05:42 PM
Hydreeeezy's Avatar
Shifting
I just recently bought my 06 Coupe, not to good at driving stick any suggestions on what rpms I should be shifting at? I don't want to burn out the clutch to fast. Thank you
Old Apr 6, 2015 | 06:15 PM
ScraggleRock's Avatar
Depends on terrain. Not gonna shift at the same points when going up hill as you would on flat ground
Old Apr 6, 2015 | 11:29 PM
Siciliang35's Avatar
It's not hard to drive a stick. Always in neutral at a red light or stop sign and foot off the clutch , that will add life to the clutch . Try shifting around 3000 rpms until You get a good feel for the car.
You know Your car when You start shifting by the sound of the engine.
Once You get a good feel You can start downshifting .
Never go passed redline unless You wanna blow Your engine. I wouldn't even take it close to redline
Old Apr 6, 2015 | 11:49 PM
Texasscout's Avatar
This car is just not easy to drive smoothly, especially the first to second shift. I have been driving sticks for 44 years and this is one of the hardest cars to master. Keep at it, you. Willll get better.
Old Apr 7, 2015 | 12:55 AM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
https://g35driver.com/forums/g-spot/...-drive-mt.html
Great Writeup
Old Apr 7, 2015 | 02:16 AM
partyman66's Avatar
Shifting RPM's are not something you can define easily for all gears or situations. You'll get a feel for the car and how rapidly you want to accelerate in each situation and eventually learn to intuitively know when to shift up or down.
Smooth shifting is all about matching your engine revs to the speed of the transmission input shaft. You just have to get used to that as it's different in any car due to gearing being different. You will probably notice that our cars are a bit harder to shift with the air conditioner on because the revs drop quicker and the gears are very close in ratio so it's more likely to drop too far and buck between gears. Shifting at lower RPM's will generally keep your shifts smooth.
Whatever you do, treat the clutch as a "gear switching mechanism". What I mean by that is that you should only be using the clutch when you want to switch gears or go from neutral into a gear. If you use the clutch to emulate neutral or to hold your position on a hill, you're going to beat up the clutch and result in premature failure. If you're on a hill and you want to stay still, put the brakes on and put your car in neutral and let the clutch out. Even if you are in neutral, just holding the clutch down is still bad for the clutch throwout bearing.
Basically just try to minimize the amounts of time that you use your clutch and just use it between gears (including when going from neutral into a gear) and when starting from a stop.
Also... never rest your foot on the clutch pedal when you have no intention of pushing it in as the light pressure on the pedal can still cause wear on the components.
Just get out there and practice though. You don't want to get stuck in a stressful situation with no confidence in your ability to get the car moving smoothly in heavy traffic or on a hill with a car right up your a$$ behind you.
Old Apr 7, 2015 | 04:42 AM
Hydreeeezy's Avatar
Thank you guys for the great advice! This helps a lot. I appreciate it.
Old Apr 7, 2015 | 04:50 AM
Like others have said, this isn't the easiest car to learn on. Also, our clutches tend to be quite expensive. It may serve you well to go find a car for $300 and go practice beating that up and just throw it away afterward. Haha yeah, it'll cost you $300, but could save you $1200 for a new clutch in yer G.
Old Apr 7, 2015 | 08:41 AM
Texasscout's Avatar
Originally Posted by anynigma
THAT's the one I was looking for last night.
Old Apr 7, 2015 | 09:02 AM
andrewvk's Avatar
this is horribly false. you can take your car to redline and bounce it off the rev limiter.
seriously i dont understand this forum sometimes.
Old Apr 7, 2015 | 09:18 AM
LoSt180's Avatar
I've been driving manual cars since I was 15, and this car was a pain to master (esp the 1st to 2nd shift). I finally went for the RJM clutch pedal mod. That product has been through a few iterations, I think it's as easy as just swapping out the whole clutch pedal assembly now. Probably one of the best drive-ability mods I've done.
Old Apr 7, 2015 | 09:22 AM
andrewvk's Avatar
i have the rjm clutch as well. and coming from a competition high tq clutch, the pedal is wonderful.
Old Apr 7, 2015 | 06:30 PM
partyman66's Avatar
There is nothing wrong with the other guys advice. If you want your car to last a very long time you will not go near redline often or at all. That's good advice. Just because your car has a rev limiter doesn't mean you can't go past it. If you are accelerating down a steep hill the downward pull of gravity can pull you past redline and if you downshift into too low of a gear it can and will overrev the engine past redline. The rev limiter just prevents the engine from using its own power to rev past the preset redline RPM by cutting the fuel feed when it gets to that RPM, but if the transmission input shaft is spinning the engine at a higher RPM there is nothing to stop it from doing so.
Revving high generally puts a lot of stress on your internal engine's components, generates a lot of heat, and will wear your motor out at a lower mileage level than if you tried to keep the RPMs down to a more reasonable level. Why do you think diesel engines tend to last so long? They spin at super low RPM's, so stuff generally takes less of a beating over a said amount of miles than another vehicle that spins at 2 to 3 times the RPMs in order to produce the same vehicle speeds. This means less wear on piston rings as well as any other part that moves or spins in sync with the motor.
Old Apr 7, 2015 | 08:47 PM
Texasscout's Avatar
That's one of the reasons I love this car, I don't have to down shift to pass some one.
Old Apr 7, 2015 | 09:21 PM
partyman66's Avatar
Downshifting is so fun if done right plus sounds cool!
