Stillen Z Tube Installed
Old May 15, 2015 | 06:24 PM
JKL1031's Avatar
Rip off the power duct for more excitement
Old May 15, 2015 | 08:47 PM
ScraggleRock's Avatar
But..power duct..
Old May 15, 2015 | 09:22 PM
LaserRedG35VS's Avatar
I believe the best option for our cars is CAI. I tested it on AFR ratio compared to the Short Ram intake, and the CAI takes in WAY MORE AIR. And then tested filters. FOAM IS BY FAR THE BEST FOR AIR FLOW. My opinion based on my testing.
Old May 15, 2015 | 10:59 PM
Urbanengineer's Avatar
And the official dumping the myth out of intake mods.
Old May 15, 2015 | 11:43 PM
giuseppe04's Avatar
Got mine installed too, nice sound, not much hp
Old May 15, 2015 | 11:55 PM
Got it installed? I hope you mean you installed it.
Old May 16, 2015 | 12:06 AM
Wat u mean? I tested it and the results are accurate. If u need proof. I will reinstall short ram and take vid of afr. And redo for cai
Old May 16, 2015 | 12:33 AM
giuseppe04's Avatar
Lol, yes yes I installed it, which means I got it installed.....thats just sad...lol
Old May 16, 2015 | 12:56 AM
gary c's Avatar
There are no WHP gains in intakes! Exposed cone filters will cost you major hp due to heat soak when it's warm! Only cone filter that seems unaffected is on Stillens CAI but that's the only one. Best option is Z-Tube and a quality drop in filter like AMSOIL. Last time I used foam filters was on my BRE prepped Datsun 510s dual side draft carbs in '72, similar to what the HKS intakes use...Gary
Old May 16, 2015 | 03:30 AM
I will keep eye on heat issue now that u mention. But really. Ive always wanted to just buy all these different intakes and test them now that i have afr meter. If im running lean, then good intake. Rich. Then poor intake. So far the AEM CAI with foam filter is outstanding. Sound. Air flow. And hopefully 1 whp lol. considering i have plenum and full exhaust.
Old May 16, 2015 | 10:00 AM
JKL1031's Avatar
I really don't understand how there are no gains from a bumper CAI. My engine hates heat soak. I have an Uprev so I could watch intake Temps and volume, but it's all over the news that CAI is no gain so I never bother.
Old May 16, 2015 | 05:57 PM
saywat?'s Avatar
I'm not worried bout heat soak with my nismo cai. The filters blocked off top to.bottom side to side. Gets all its air from the driver side vent. I don't drive in traffic. I'm good to go
Old May 17, 2015 | 08:19 AM
whutch1's Avatar
Originally Posted by saywat?
^wat do u mean at idle it simply purrs?
Did I say "purrs"??? my mistake.. I meant "Grrrrrr's"
Old May 17, 2015 | 04:20 PM
saywat?'s Avatar
Intakes do nothing at idle. That's the exhaust ur hearing
Old May 17, 2015 | 05:50 PM
  #30
JKL1031's Avatar
better in better out
