wheel bearing problem after replacement
hey guys.. i have no idea where to turn now. im kinda of at the point where im going to star throwin tools across the garage.
so i have a bad rear passanger wheel bearing. bought a complete hub and bearing so i didnt have to press anything. ok so it was a pain in the *** getting the old one out. threw the new one in... mind you matching part numbers and all. tightned everything up and reviewed a couple DIY to make sure i had everything down. take it for a drive and 1 block later the axle spindle seems to be to small for the bearing. has anyone had this issue because i was under the impression that 03-06 had the same axle spline diameter.
Need more info?
Are you saying the axle shaft in the rear is too small to fit the splines of the rear hub?
Did you replace the hub with an OEM unit? Did you get a rear one for the RWD car (looks like a flower) or did you accidentally get a front hub for an AWD car (circular)
rezendvous420
May 31, 2020 01:26 PM
