Camber or Toe Wear?
Old Jun 10, 2015 | 05:40 PM
jacobgriz's Avatar
Originally Posted by ScraggleRock
Yes, it could, but only if your bushing decided to go bad after your toe was set. I'm sure your bushing was already bad when you got your toe set, so it still shouldn't have moved from the shops settings. Unless you hit a curb or something
So you think the only way the toe could be off is if the alignment was incorrect in the first place? What if it's a dynamic problem and not static, so that the toe moves when braking or accelerating?
Old Jun 10, 2015 | 06:08 PM
ScraggleRock's Avatar
That would mean they set it but didn't tighten the jam nuts. I mean your toe would obviously go out over time due to other things wearing out, but it should not happen that quickly.
If I were you I would change your comp rod bushings and lower control arm bushings to polyurethane, buy a lifetime alignment somewhere and get it realigned.
Another question: have you taken anything apart since you had the alignment? Any time you take off any suspension components it will throw your toe off. These cars absolutely require a lifetime alignment. Mine has payed for itself many times over.
Not sure if you know how it works (not insulting your intelligence, I just don't know.), but toe kills your tires by literally dragging them. Imaging you have a pair of roller skates on and you point your toes inward toward each other. It would be really hard to roll forward, and if you did it would basically drag your wheels sideways. That's what wears your tires out.
Camber is just the angle at which you wheel sits. It doesn't necessarily cause excessive friction.
Old Jun 10, 2015 | 06:49 PM
gary c's Avatar
I got it done at redline speed worx. It's a Racing Shop that focuses on lowered or performance cars so I highly doubt they would screw it up. I was thinking it could be compression rod bushings. I'm going to take a look at the suspension.
A good alignment shop would have inspected your entire suspension prior to aligning your coupe and recommended replacing worn parts! I just took my wife's Vette to get aligned and they found two bushing that needed replacing, that's how quality shops operate regardless of the cool name on the outside! So have the CRBs replaced, get another alignment along with two new tires and pray they get it right this time.
Gary
Old Jun 10, 2015 | 09:00 PM
jacobgriz's Avatar
That's true actually. Could the lower ball joint have anything to do with it? I have a feeling a bunch of parts are worn, but the lower ball joint looks squished to one side. I should mention my tire went flat before I got new tires about 8000 miles ago and the threads were showing them as well. That was before the alignment. That's another reason I think it could be dynamic.
Old Jun 10, 2015 | 09:55 PM
The lower ball joint wouldn't affect it, no. It should be changed if its clunking or leaking tho. Replacing the LCA and CR bushings with poly and getting it aligned properly should fix your problem. Again, I would suggest a lifetime alignment from a place with a decent reputation. Also, learning about what you want will help you talk to the techs and keep them from half a$$ing the job next time.
Old Jun 11, 2015 | 10:36 AM
jacobgriz's Avatar
Is this something I could do myself? I installed the coilovers myself and I'm not trying to spend crazy money after having to buy 2 new tires.
Old Jun 11, 2015 | 10:41 AM
jacobgriz's Avatar
Because its hard for me to tell with the compression rod bushings, but I can tell the Lower control arm bushings are cracked and even a little bit to the side.
Old Jun 11, 2015 | 11:46 AM
gary c's Avatar
Again Jacobgriz, these are all worn suspension issues your Race Shop should have suggested you replace. Nothing feels better than a tight suspension where everything is working and your alignment is spot on. It's sad when you're more aware of what is worn out and your alignment mechanic doesn't mention it...they're not the best place to have your G worked on! In fact, I'll suggest the tire wear was due to misalignment!
Gary
Old Jun 11, 2015 | 12:13 PM
Mustang5L5's Avatar
Pics?
Old Jun 11, 2015 | 05:21 PM
jacobgriz's Avatar
Took the advice of you guys and brought it to a different shop for a suspension inspection. He said my bushings look good and everything does, he thinks it's just because of the camber and that the wheel spacers are exaggerating it,and we're going to do an alignment. I already have the rear camber kit so the plan now is to mount the 2 new tires (they came today) install the front camber kit (myself, pretty basic) and then raise the car up just a bit and align it.
Thanks for the help to everyone that replied.
Old Jun 11, 2015 | 05:53 PM
jacobgriz's Avatar
Most likely going to get the spc front camber kit
Old Jun 12, 2015 | 12:51 PM
Mustang5L5's Avatar
Spacers would exaggerate it. How big of a spacer are you running?
Old Jun 12, 2015 | 03:50 PM
jacobgriz's Avatar
15mm in the front, 25mm in the rear
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
