New Brake Pads
Old Jun 15, 2015 | 10:52 PM
rsingerG35's Avatar
Originally Posted by gary c
These are probably the only two members that haven't wanted to upgrade their brakes! OEM brakes do everything they posted plus leaving an inch of brake dust on your wheels by just going around the block! HAWK HPS pads do the very same job with the exception of all that fugly dust! You do need to do the "Bed In Process" (search) when installing them for 30% better stopping ability...Gary
The truth is 03/04 base brakes weren't very good at all. The upgraded 05+ brakes are much better with larger rotors and dual piston front calipers. Not to mention the pads are much better.
Old Jun 15, 2015 | 11:01 PM
rsingerG35's Avatar
Originally Posted by bmars06
thanks! What p/n is used for the rear pads?
44060-eg00k
Old Jun 16, 2015 | 01:18 AM
bmars06's Avatar
Actually bmars06, there are 3 different types of Hawk pads for our first gen G35s. Check out www.thetirerack.com, they show all 3 and how they are rated/compaired. If you decide on the Hawk HPS pads get them from the vendors on our Marketplace for the best price...Gary
I took a look at the website. Only only have 1 version of the "HPS" for FRONT pads. There are other Hawk versions (HP Street/ HPS 5.0) though but only one "HPS" (the blue box). However, if you look at the Hawks website for a 2006 Infiniti G35 Coupe, you'll see that there are two different kinds of Hawks "HPS" FRONT pads. One is larger than the other. What's the deal with the larger pad? Is it for a Brembo caliper or something? Will it work on a non-Brembo caliper?
Thanks for all the info about the OEM pads, guys.
Old Jun 16, 2015 | 06:59 AM
leo38cheng's Avatar
New Brake Pads
i have an 05 coupe and looking at brake pads as well - so oems are best? i heard hawks are bad in cold weather - any other recommendations?
Old Jun 16, 2015 | 09:40 AM
Mustang5L5's Avatar
Originally Posted by leo38cheng
so oems are best?
I wouldn't go that far. What pads/rotors are the "best" all depends on what you are doing with the car.
Driving to/from work? OEM will be fine (except 03-04...those suck) Weekend Autocrossing or roadcourse racing? Aggressive street racing? Probably something different.
There's a lot of engineering behind certain brake pad/rotor combos that aren't generally widely understood. Pads tend to be designed for certain purposes and it's up to the user to select the right pad for what he/she is doing with the car.
Stoptech has some really good technical papers worth a read.
http://www.stoptech.com/technical-su...l-white-papers
Old Jun 16, 2015 | 11:50 AM
Deepdiver's Avatar
incorrect, I've had experience with oem, carbotech, stoptech, and your beloved Hawk HPS. I've bed them all in like an expensive hooker. Hawks will have less fade, BUT they have an underwhelming initial bite and they are horrible in wet weather when compared to the others. For what the OP has described what he is looking for, OEM is his best option.
Old Jun 16, 2015 | 12:04 PM
leo38cheng's Avatar
how about rotors? I'm planning to go OEM as well.. should I just pick up Stoptech blanks? or should I do drilled?
Old Jun 16, 2015 | 12:36 PM
gary c's Avatar
I've driven SLICK in the worst rain on PCH I've ever seen coming home from Santa Barbara and my HAWK HPS pads never once felt like they weren't working 100%! Then I upgraded to DBA rotors and the pads lasted 50% longer, so worth the cost!
Rotors? You have many choices, check out our Marketplace under vendor brakes. I'll continue using my DBA rotors because they stop very well and double the life of my HAWK pads. You can go with slotted/drilled but it depends on which rotor you're buying, some have issues with cracking...my DBAs do not!
Gary
Old Jun 16, 2015 | 12:56 PM
leo38cheng's Avatar
Gary
which dba do you have?
Old Jun 16, 2015 | 01:41 PM
Mustang5L5's Avatar
A lot of guys run the stoptech/centric blank rotors. I have them as well, and am on my second set.
Not a fan of drilled rotors myself. If you want the look, go for it, but don't expect any difference in performance over blank rotors. Pretty much just for looks on a street car
Old Jun 16, 2015 | 01:46 PM
leo38cheng's Avatar
are you using oem brakes?
Old Jun 16, 2015 | 02:08 PM
Deepdiver's Avatar
I have a vote for Adams rotors (site sponsor). The fit, finish, and material quality is all there. Very happy with them.
Old Jun 16, 2015 | 06:24 PM
bmars06's Avatar
So does anyone know why the Hawk website has two different HPS FRONT pads list for my 06' coup? One is large than the other. Which would you use for non-Brembo calipers? Links to the two pads are below.
http://www.hawkperformance.com/perfo...pads/hb268f665
http://www.hawkperformance.com/perfo...pads/hb387f547
Old Jun 16, 2015 | 06:39 PM
gary c's Avatar
Drilled/Slotted DBAs with the gold lug area! Just installed a new set of HAWK HPS pads and had the DBA rotors turned, good for another 30K miles. I believe it was the 387s that I installed last...Gary
Old Jun 16, 2015 | 06:43 PM
  #30
leo38cheng's Avatar
how much are the dba compare to the stoptech
