Headlight fitment fix?
Old Jun 15, 2015 | 05:21 PM
Kicknshift's Avatar
Some a**hole backed into my car and did minor damage. A few scratches on my front bumper and got my headlight aswell. The headlight isn't damaged just the tint overlay is slightly peeled off but I plan on removing that anyways. My main concern is this fitment issue.
As you can see the headlight is shifted up. Is this an easy fix or should I have a professional get it right?
Old Jun 15, 2015 | 07:50 PM
Extreme Dimensions's Avatar
It looks like the mounting tabs were bent. Take both driver & passenger lights off and compare the mounting points. See what is damaged and gauge if you can fix it.
Old Jun 15, 2015 | 08:23 PM
HypedAndy's Avatar
what he said^ if it was moved while the bolts holding the tabs down were torqued in place it's most likely bent. was it a hit and run? or did you find the person who hit you
Old Jun 16, 2015 | 02:35 AM
Kicknshift's Avatar
Okay thanks guys sounds easy enough.
Unfortunately I did not. I asked the store I was parked near if they had a camera on the spot but they didn't
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
gatorglaze
Sep 10, 2015 12:03 PM
RA081024
Aug 18, 2015 07:03 AM
joedaddy1
Jul 28, 2015 02:58 PM
