URGENT help please. Clutch not engaging
Old Aug 30, 2015 | 02:13 PM
TheBay's Avatar
Hey community,
So last night I got stuck by a park because my clutch went out all of a sudden. I have a 2006 G35 coupe and just last January i got the clutch (JWT) and the hydraulic system replaced. The clutch fluid seems to be fine but whenever I try to put it in 1st gear or even reverse, it just revs up and doesn't move or catch on to the gears. It just stays there and the rpms go up. The only thing that I can say that might feel different about the car is the clutch pedal pressure seems like it went down.
I really need to figure this situation as I don't really have a reliable 2nd car I can use whenever.
Any help is appreciated!
Old Aug 31, 2015 | 04:43 PM
TheBay's Avatar
Old Sep 3, 2015 | 08:25 AM
wuzz-upp's Avatar
Originally Posted by TheBay
You need to do some basic troubleshooting.
1. Clutch fluid level?
2. Jack the car up.
3. Inspect linkages and look for evidence of fluid leaks at all lines, operating cylinder and
clutch master cylinder cylinder.
4. Have someone depress the clutch pedal and see what action is taking place at the
operating cylinder. The Withdrawal Lever should move through a full travel, this actuates
the release bearing which actuates the pressure plate. It is actually a basic system to
troubleshoot. If you get little to no action at the operating cylinder, then either your master
cylinder or operating cylinder is by-passing fluid internally.
5. Or take it to a shop and have it checked out.
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
mattdg35
Sep 14, 2015 11:28 AM
