Front Vertical Strip Lights Replacement
Old May 9, 2003 | 12:49 AM
SKYL1NE's Avatar
Can anyone tell me how to change the front vertical ugly amber strip light? Also can you tell me if there is a good clear corner bulb. I have the clear corner but the amber bulb looks bad. Also one more, what is a good replacement for the fog light bulb.
Thanks,
Alan:-)
Old May 9, 2003 | 10:59 AM
SKYL1NE's Avatar
Re: Front Vertical Strip Lights Replacement
Hi,
and thanks for your reply
Alan
Old May 14, 2003 | 12:05 PM
MustGoFastR's Avatar
Where can I get those LED lights? Will these fit in the Coupe's clearance lights?
Old May 14, 2003 | 01:40 PM
That's great. Thanks. I assume these are direct drop-ins; do you have any pics of them installed? I'm wondering if I should go for the big single or the cluster of 4. I want the strip to light all the way with a white light, but don't want it to be overpoweringly bright.
Old May 15, 2003 | 11:54 AM
afr0puff's Avatar
Supa Dupa Moderator
The strip will light up entireley, depending on which bulb you use. See this website:
http://www.anythingbox.net/bulb/
Old May 15, 2003 | 08:36 PM
afr0puff's Avatar
Supa Dupa Moderator
Oh, yeah... it does gradually fade. I thought you meant that ALL bulbs would be like the OEM bulb that fades before it reaches the bottom.
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
Tylerttn
Jul 14, 2015 10:11 PM
