Wtf water leak in my car
Old Jan 27, 2016 | 11:39 PM
Terry_G35's Avatar
Can somebody please explain to me why and how does water drip on my feet unexpectedly from under the drivers side of my car why it was raining in good ol SoFlo. Does anyone know what the culprit is before anything catches on fire or electronics start malfunctioning. Where would the the leak come from? How can I fix it? Thanks
Old Jan 28, 2016 | 12:10 AM
partyman66's Avatar
You may have a leak in the seal around your windshield. Has anyone done any aftermarket electronics work on your car?
Sometimes people run a wire through the firewall and into the cabin by cutting a hole in the firewall or cutting a hole through the seal around the steering shaft and if it's not seals properly can result in leaks.
You really need to go out there with a hose on a sunny day and have someone else standing outside the car with a hose spray water onto various parts of the car while you're inside looking for leaks. I've done this on countless cars and it pretty much always flushes out the source of your leak. Be prepared to remove interior parts too since many leaks originate from areas that aren't exposed in plain view.
Old Jan 28, 2016 | 12:59 AM
Tyke420's Avatar
This is weird... I washed my car awhile back and found that a little bit of water was on the floor on the passenger side. Not a whole lot but I definitely noticed it.. Never dripped when I drove in a down pour one night... Never really looked into that much but would assume it's coming in from the fire wall somwhere...
Old Jan 28, 2016 | 07:43 AM
xXHotelCrazyXx's Avatar
Are you using the AC when this is happening?
Old Jan 29, 2016 | 11:41 AM
Terry_G35's Avatar
Thanks I will call a buddy of mines to help me figure out this thing out but if there's no hole or crack could it also be from the outside air vents right below the windshield?
Old Jan 29, 2016 | 11:44 AM
Terry_G35's Avatar
Nope I was sitting in my car waiting for my class to start. The car was off the whole time I got a little puddle on the floor mat too, thank god I have rubber floor mats.
Mustang5L5
Nov 8, 2019 11:21 AM
TheIronYuppy
Dec 29, 2016 02:31 PM
Duriisimo
Lights
Mar 10, 2016 12:11 PM
Treewax
Jan 25, 2016 11:32 PM
