Front, Driver's side CV axle replacement
Old Jan 22, 2016 | 09:20 AM
Mustang5L5's Avatar
AWD car of course. Anyone every replace the front driver's side CV axle?
I'd done the passenger side one, but looks like the driver's side one bolts on with 3-4 small bolts.
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/fax.pdf
Page 19 says to replace the bolts after each disassembly. Anyone have a P/N or am I stuck going to Nissan/Infiniti and painfully looking through their parts computer and paying $7/bolt.
My symptoms are an occasional clunking, and not a "card-in-spokes" sound coming from the front end when I move. The sound varies in volume and I cannot determine which side it is. It does go away when I turn right, and I don't suspect a wheel bearing because the sound does not change if I rock the car at speed left and right to shift the weight. I get various clunks when reversing or going forward as well....seems like the driver's side is the origin but i'm not 100%
I changed the pass side CV axle last spring due to a torn boot. I still have it and can reboot it and install to see if the reman is the cause of the noise, but I also just ordered a driver's side CV axle.
I keep wondering how much longer I want to deal with troubleshooting these things.
Old Nov 8, 2019 | 11:21 AM
fitgineer_93's Avatar
Mustang, did you end up replacing your front left axle? Was it the cause of the clunking in the front end?
Shaunjr
Aug 31, 2018 11:23 AM
Skeeter SS
Jun 27, 2014 05:02 PM
youloze
Jul 31, 2012 06:46 PM
spinn
Jan 3, 2011 02:21 PM
Andy2434
Drivetrain
Apr 28, 2009 06:22 PM
