2005 G35 waterlogged ballast!
Old Feb 23, 2016 | 06:20 PM
bongoz's Avatar
Unhappy 2005 G35 waterlogged ballast!
I have a Canadian G35 with a cracked left headlight lens.
I'm not concerned about the crack aesthetically. I bought the car with a left burnt out HID, expecting it to be a simple bulb replacement but it turned out to be a ballast that's been badly water damaged. When I unscrewed the ballast and removed it a bunch of water drained out the bottom of the headlight.
While I was replacing the HID bulb before I knew it was a ballast issue, I discovered there was no HID rear cover. I'm not sure if the water that my ballast was submerged in was caused by the headlight crack or lack of a rear HID cover?
For any confusion here is a picture of the cover I'm talking about:
Here's a picture of my headlight crack:
Any help or opinions would be greatly appreciated
I'd really like to avoid purchasing a new headlight. I have no idea where I could find a Canadian headlight with DRL, already tried all the auto wreckers within a 1-4 hour drive with no luck.
Old Feb 23, 2016 | 10:42 PM
NemesisGee's Avatar
Have a look here...lots of Canadian recyclers on there.
http://www.car-part.com/
Or you may go with some fresh aftermarket ones....
http://www.amazon.ca/s/ref=nb_sb_nos...G35+headlight+
Richie8
Feb 9, 2016 08:58 PM
drosu1977
Dec 30, 2015 09:38 PM
Jamean
Interior
Dec 25, 2015 10:58 PM
zanyskye
Dec 19, 2015 12:55 AM
tha_ape
Dec 15, 2015 09:07 PM
