Urgent Please help!
Old Mar 19, 2016 | 09:54 PM
kethnguy's Avatar
Urgent Please help!
I just installed a whole new clutch master/slave cylinder and lines and i am going through bleeding now.
I have done the clutch pedal pump 5 times and hold on 5th, open bleeder, etc process about 10 times now and my clutch pedal still has not come back up on its own (no pressure)
What am i doing wrong? PLEASE HELP!
Old Mar 21, 2016 | 05:27 PM
telcoman's Avatar
Veteran: Army
Originally Posted by kethnguy
I
Probability not following the FSM
http://www.nicoclub.com/FSM/G37/Sedan/2009/CL.pdf
Telcoman
Old Mar 21, 2016 | 05:59 PM
kethnguy's Avatar
I actually am using that procedure as stated in my OP. still not working after many many many repeats
Old Mar 23, 2016 | 10:12 PM
saywat?'s Avatar
the trick is to do it quickly one after another
Old Mar 24, 2016 | 10:57 AM
LoSt180's Avatar
Did you bench bleed the master cylinder before installing? Try vacuum bleeding if pumping isn't working out for you.
Also, once you open the beeder, the pedal isn't exactly going to come back up on it's own. Does it work after you pop the pedal back up?
Old Mar 24, 2016 | 01:48 PM
yosip1115's Avatar
Vacuum bleeding was no help for me. What helped me was pulling the pedal up all of the way manually, then tugging on it some more and holding it for a few seconds before pumping again. Also adjust the master cylinder rod so that you are maximizing the travel of the master cylinder piston.
Old Mar 24, 2016 | 02:31 PM
saywat?'s Avatar
fsm states not to use a vacuum bleder
iMightBe
Jul 11, 2018 03:17 AM
DumpsterJedi
Aug 16, 2016 02:01 AM
Conissah
Brakes
May 9, 2016 04:54 PM
DiGil
Drivetrain
Apr 24, 2016 09:54 AM
RedSER13
Apr 6, 2016 01:39 PM
