HELP gauge cluster advice needed
Old Mar 31, 2016 | 12:00 AM
Albanian122's Avatar
Ok guys so I bought the Nismo gauge cluster for an automatic g35. I have an 06
Question I have is will it work or do wires have to be rearranged or spliced
Anyone who has done any Cluster work please chime in
Old Mar 31, 2016 | 01:04 AM
.cakestar's Avatar
man thats a tricky one. most of the guys that did the 05 --> 06 interior conversion did need to get repinned and spliced. afaik i havent seen any comprehensive guides on doing that conversion
Old Mar 31, 2016 | 01:15 AM
Any idea how the 06 cluster compares to this ??
Old Mar 31, 2016 | 01:36 AM
.cakestar's Avatar
i mean you would just have to pull up the fsms for both and check the pin outs and then try to rearrange the pins
Old Mar 31, 2016 | 01:41 AM
I would need another 13 pin according to pictures. Just not sure if I can have someone attempt the retrofit for me or I might have to just sell the cluster fml I need to stop buying **** lol
Old Mar 31, 2016 | 02:08 AM
.cakestar's Avatar
but i mean even the plugs are different
Old Mar 31, 2016 | 02:11 AM
.cakestar's Avatar
yeah exactly. lol id go with the 06 cluster. you can get a custom gauge face made that is in the same style as the nisml if you wanted. it could look exactly the same with no mph if you wanted.
the only way to get yours to work is to try to find the male end of the harness and cut it. maybe a junk yard or try to go through mouser to find the actual connector though i think it will be hard to find.
the 06 cluster is cleaner though and if you ever wanted to do an led conversion its much easier and cleaner with the 06's
vqpowahhhh
19 Inch
Apr 7, 2016 09:57 PM
strrmx
Mar 31, 2016 02:07 PM
Mignav01
Engine - Intake/Fuel
Mar 30, 2016 08:03 PM
Sean Menick
Mar 27, 2016 01:21 PM
Albanian122
Mar 26, 2016 09:22 PM
