Took my car to Firestone for an alignment today, they told me that they can't adjust the front camber or caster, and that my rear camber bolts are seized. I have an 04 coupe with OEM rays so I had them run the alignment using an 05 model with the 19s.
Few questions:
1. What specs should they normally be able to modify? They gave me a sheet stating "the manufacturer does not specify front camber or caster adjustments."
2. What do I need to do to fix the rear camber, if anything?
3. What do you think of my specs:
L/R Front Before:
- Camber -1.2, -1.3
- Caster 8.4, 8.2
- Toe -0.03, -0.01
