6MT continuing clutch woes after clutch replacement + bleed
Old May 9, 2016 | 05:35 PM
synned's Avatar
Hey guys -
2005 G35 Coupe 6mT
So for the longest time I've had the sticky clutch petal. I didn't think it was too big of an issue.
Anyway, after 40k miles on a new clutch, all of a sudden I can't shift into gear.
Get towed, told I need a new clutch. Weird, but ok.
Get it back - still sticky petal and still hard to shift gears after driving a while.
Bled the fluid, was filthy.
Was a little better, but still - after driving about 45 minutes, every gear gets hard to get into. I have to force it in.
I noticed that even when the clutch is all the way on the floor, it is a tiny bit engaged .
So I'm thinking the slave cylinder is bad, and I also think the trans fluid is probably filthy and going to do a flush.
What are your guys thoughts on the master/slave cylinder? Likely culprit?
I just hope I haven't ****ed my synchro's up for good
Thanks guys
Joe
Old May 9, 2016 | 07:14 PM
deeliciousqueen's Avatar
G35 coupe 6mt
I had sticky clutch feel and hard to gear like yours, they get worst especially on a hot weather. When I upgraded my clutch and FW, I replaced the master slave and clutch slave as well, the issues are gone.
IMO, the oem master and clutch slave are weak depending on the mileage and how it was treated before. Regardless, you should've replaced them altogether since you're there already and save you $$. GL
Old May 10, 2016 | 01:38 PM
synned's Avatar
Thanks. I think I will start with the slave cylinder, do it myself, it seems pretty straightforward.
How bad was the master and slave cyl replacement? I just bled the slave so it seems like it'd be pretty straighforward from what I saw under there.
Also, where did you buy yours? OEM?
Old May 10, 2016 | 05:48 PM
telcoman's Avatar
Veteran: Army
Originally Posted by synned
Hey guys -
2005 G35 Coupe 6mT
Well it was a big deal!
Ever peruse the FSM?
Or did the shop that did the work?
http://www.nicoclub.com/FSM/G35/Coupe/2005/cl.pdf
It appears to me that you used an unqualified shop that didn't really know what they were doing and possibly used questionable parts.
There are a ton of threads on the failure of CSC and it failed on my previous 06 G35 but was replaced under warranty.
IMHO you would have been better off having the work done at a dealer.
A clutch should last 200k miles if properly driven and not abused.
I traded in my 06 G35 with 171796 miles still with the original clutch.
Telcoman
Old May 10, 2016 | 07:03 PM
G35 coupe 6mt
Actually, for POM I would replace both slave and master. I went with oem zspeed, z1 or conceptz should have them, ebay oem but beware and do your search and ask the seller.. you don't want china parts.
I had a shop did all the work, one time tranny drop (C&FW) replaced everything and not having to worry about it again.
If you decided to DIY, use telcoman's link as a guide. If not, find a reputable Nissan shop around your area. If you're rich go to stealership. GL
joeslates
Feb 6, 2018 09:40 AM
bongoz
Feb 23, 2016 10:42 PM
frodos_4door
Feb 20, 2016 01:08 PM
y0gur7
Feb 17, 2016 09:41 AM
Ricardo_Galeno
Feb 11, 2016 03:53 AM
