gas pedal bushing (long post)
Old May 9, 2003 | 10:16 PM
phat911's Avatar
To all, Hello!
I just finished installing the aluminum pedal set. The clutch and brake pads were a pain, but nothing compared to trying to install the gas pedal without a bushing. The bushing is the part that no one has, good luck! I went to Lowes hoping for a miracle and found a workable solution. In the hardware section under the special fasteners, I found nylon spacers
(size: .562x.375X1/2) This spacer will fit nice and snug on the pedal, problem is the inside hole is too large for the gas pedal rod. I also picked a metal bushing that I ended up reaming out to fit the gas rod, this is the hardway. The better way to do this is to take the nylon bushing, mix up some JB Weld fill the center bushing hole, have a few beers while the JB Weld sets up, then drill out with a 3/8 drill. Test fit and use the 3/8th drill to ream out where needed. Use the quick set JB Weld and don't forget to add a little grease to the inner hole of the new bushing before permanently mounting the pedal. cut the top clip off the original pedal and reuse on the new one. Total cost is about $4.00 bucks (not including the beers) After the JB Weld sets, you have about 20 minutes worth of work. After I completed the job, the New Castle beer just tasted better!!
To all, Good Luck!!!!
Phat911
Old May 10, 2003 | 08:31 AM
Gidyup's Avatar
Re: gas pedal bushing (long post)
Grubbs Infiniti has these bushing at web site
http://www.infinitiwholesaleparts.com/en_US/
Located in accessories, interior page
Or order from your local infiniti dealer using the bushing part #'s
G35 Pedal Aluminum Kit part #’s
Pedal-Accel 18016-AB010
Brake/clutch pad 46531-AB000 Need 2 for 6MT only
Footrest Assy 67840-CD011
Bushing 18014-8H601
Bushing 18014-AB000
Auto Brake Cover Pedal pad 46531-AB010 Need 1 for Auto only
Old May 10, 2003 | 09:55 AM
RamboRami's Avatar
G35driver.com Moderator
haha yeah, grubbs has the bushing...sorry you had to go thru all the trouble dude
<font color=green>-Ramb0</font color=green>
Blakearold
Aug 19, 2015 10:20 AM
tiguy99
Jul 26, 2015 01:39 PM
