Front suspension noise after some parts were changed
Old Oct 3, 2016 | 12:09 PM
Tylko Kazik's Avatar
Hello everyone , I wanted to freshen my car up a bit to first i changed all 4 shocks to kyb . The car drove fine with no noises. After about a week after i decided to do the end links and i think thats when i started hearing the noise but i though i was my compression arms since my camber was off so i did those and the noise is still there . I re checked if everything is thigh . My friend think its the sway bar bushings because i didn't do them when i did the end links (waiting on parts from dealer). Can sway bar bushings make a thump noise when going over bumps ? you can acually feel something by the right leg when going over bumps , i also just got 4 new wheels and tires i want to fix the noise before going to alignment . its a pretty loud noise
i have used those http://www.ebay.com/itm/111625483740?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Oct 4, 2016 | 09:30 AM
LexD's Avatar
Originally Posted by Tylko Kazik
... Can sway bar bushings make a thump noise when going over bumps ?
No.Sway bar bushings would not make a thump, thud or knock. They might squeak if not properly lubed.
I would double check the torque specs on the end-links and make sure you've torqued the compression rod bushings when the vehicle is loaded (lowered, sitting on spring weight) as well.
Old Oct 4, 2016 | 11:20 AM
i have checked twice already ..
Old Oct 4, 2016 | 11:37 AM
coffeysm's Avatar
I doubt it's your bushings unless they're completely destroyed. Check the torque and the nut on the top strut. Jack up the car and hit with a hammer around the tire to see if it makes any noises.
Old Oct 4, 2016 | 03:53 PM
Looks like one of my new kyb struts is leaking , i just noticed some oil residue on it that i missed before thinking its wd40 . i have installed them a month ago ? defective part?
I took both of the sway bar links off to isolate the problem , the car was still making the noise but it was not as easy to hear , then i noticed the slight wet shock .
Old Oct 4, 2016 | 03:54 PM
anyone ran into blown kyb so fast ? is this possible ?
Old Oct 5, 2016 | 07:52 AM
Blue Dream's Avatar
I drove ttrank's car solo
Anything's possible, life's not perfect you know.
Old Oct 6, 2016 | 10:02 PM
ended up replacing the shock , car drives like new , also replaced all swaybar bushings . easy job
davidredg
Jul 28, 2016 08:03 PM
stevoo88
Jul 27, 2016 11:29 PM
rwdxtacy
Jul 22, 2016 09:08 AM
evan2k
19 Inch
Jul 6, 2016 11:09 AM
