Suspension Problems
Old May 5, 2017 | 12:59 PM
Dwoodson's Avatar
Suspension Problems
Having and issue with the rear tires wearing out with in 10k miles. Going to replace the strut assembly, but I want to make sure I am getting good quality parts. I am in an 04 g35 coupe with sport suspension. Any suggestions?
Old May 5, 2017 | 02:08 PM
03G35C6MT's Avatar
You can get the camber arms from Z1 (might as well get the front as well). These cars came from the factory with more of a sporty suspension set up which will cause the uneven tire wear.
Old May 5, 2017 | 03:11 PM
Dwoodson's Avatar
I know they'll be faster wear on them, but about 12 - 15k is all I am getting out of the tires.
Old May 5, 2017 | 04:14 PM
03G35C6MT's Avatar
Is it just wearing on the inside?
Old May 5, 2017 | 05:00 PM
Dwoodson's Avatar
Yes the inside inch
Old May 5, 2017 | 08:08 PM
Dwoodson's Avatar
I have bought KYB struts, and looking into. Ontrol arm bushings. Anything else besides the camber
Old May 5, 2017 | 08:25 PM
03G35C6MT's Avatar
I would just get the camber kits from Z1, I think they are like 100 bucks. Cant beat the price to save the tires.
Old May 5, 2017 | 09:38 PM
gary c's Avatar
Gotta love logic!
Some part of your rear suspension is worn to the point it's causing your inside wear issue! Camber kit won't fix what is broken...but still a good idea! Run your G past a quality independent alignment/brake shop to figure what needs replacing so you don't waste your $$ on parts you don't need!
Gary
