Engine Idle and Clutch
Old May 28, 2017 | 01:27 AM
phyerb's Avatar
Owned 2003 6MT Coupe since November 2003. Not any engine problems until now.
When starting the car, after depressing clutch pedal fully, the engine will not start.
In fact there is no ignition sound at all.
When she does start, the idle (RPM) is so low that the engine will stop. Have to goose the gas pedal for it to stay running. When engine warms a bit it run fine. But I think idle is too low
What is baseline idle number? And how do I fix the issue when starting car?
Thank you for helping.
Old May 28, 2017 | 07:45 AM
Urbanengineer's Avatar
Pull the negative cable and turn on the lights. Wait until there is no power left. Put negative cable back on. See if anything changes.
Old Jun 25, 2017 | 01:09 PM
phyerb's Avatar
Thumbs up
Will do ASAP. Thank you for responding.
Old Jun 27, 2017 | 01:07 PM
Hope it works for you. Sometime the reset helps us with our G's.
Old Jun 27, 2017 | 02:25 PM
RichardP9's Avatar
If that doesn't work try the computer reset procedure or idle relearn procedure.
cleric670
Jun 11, 2017 07:29 PM
03G35C6MT
Jun 7, 2017 09:49 AM
deathstroke1160
May 17, 2017 12:04 PM
DETT
May 10, 2017 03:35 PM
g35shane
Intake & Exhaust
May 4, 2017 09:09 PM
