Right tire making a womp sound when braking
Is the rim damaged?
Telcoman
Everything Telcoman said, also when the tire is off inspect brake pads and rotors, might be a warped rotor causing the shudder. It's the middle of summer though and this is typically when tires give out due to age.
Telcoman
Welcome to the G35 Driver forums!
Out of balance tires don't make much of a noise, nor do warped rotors you feel both in the steering wheel! What do you tires look like, are the insides extremely worn? Drop by your local independent brake/alignment shop, they'll know what to look for in an instant! I'd sooner think it might be wheel bearing, they make noise and cause what you describe!
Gary
Gary
G35-MD
Apr 28, 2005 01:02 AM
