What do you think about this Z Tube?
Old Aug 22, 2017 | 03:33 PM
TheGrayt1's Avatar
http://www.ebay.com/itm/Intake-Z-tub...RWnmCe&vxp=mtr
Looking to do my first mod on my new G35 and was curious if this with a stock airbox and K&N filter would give a nice boost in performance and sound?
Old Aug 22, 2017 | 05:44 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sound yes, performance... maybe 1hp, it's more of a setup for an actual power builder like the plenum spacer and other stuff.
Old Aug 22, 2017 | 07:44 PM
Blue Dream's Avatar
I drove ttrank's car solo
Sound increase will be minimal but there and performance is debatable, especially since you're looking at a metal tube. It will attract heat and thereby introduce more heat to the intake air than a plastic tube will. But it will look cooler.......
Old Aug 22, 2017 | 09:41 PM
partyman66's Avatar
I actually noticed a surprising tone change in my car's exhaust way back in '05 when I put the Z-tube in my car. I never thought that it would make such a difference, but you can definitely hear it. Sounds more like the noise you expect from a 350Z exhaust than the somewhat quieter G35 in the midrange after the "upgrade".
Old Aug 23, 2017 | 08:42 PM
Blue Dream's Avatar
Hmmm, I guess since I added a z-tube and a pop charger (lolol I was a foolish noob back then) I attributed the sound increase to the JWT pop and not the z-tube. Good to know though, thanks.
Old Aug 24, 2017 | 09:14 AM
gary c's Avatar
You do not want the Z-Tube you posted! Any metal intake will cost you HP the minute your under hood temperature increases. When it's really hot there's a possibility of being passed by a old VW bus...as an example! Stillen makes Z-Tube that's not effected by heat since it's made of plastic composite, they're perfect for our G35s! All the Z-Tube does is change the sound with little or no HP increase, but the sound is cool!
Gary
Old Aug 24, 2017 | 01:03 PM
TheGrayt1's Avatar
I am going to shy away from this one and probably go with the Stillen. Would a stock air intake tube from a 350Z bolt right up to my G35 with the stock air box though?
Old Aug 24, 2017 | 04:38 PM
partyman66's Avatar
You didn't mention what year your car is. I know from 2003 and 2004 the stock intake pipe from a Nissan 350Z swaps right in because that's what I have on my car.
Old Aug 24, 2017 | 04:41 PM
G2B35AGN's Avatar
Swapped right into my 2006 coupe too, no muss no fuss.
Old Aug 24, 2017 | 04:44 PM
TheGrayt1's Avatar
Yea I have an 06 G35 so just making sure I can grab any intake tube from a 350z at a junk yard and swap it over.
Old Aug 25, 2017 | 11:11 AM
Blue Dream's Avatar
Yes you can, the Z tubes fit all 3-06 sedans as well.
Old Aug 25, 2017 | 04:13 PM
partyman66's Avatar
That's a completely untrue statement.
Air is one of the worst conductors of heat. If anything it's an insulator. It's not going to pull any heat at all from the surrounding material of the pipe with the engine running no matter how hot that pipe is. The air is flying through that short pipe at such a high volume that it will only be in there for a fraction of a second. What matters more is where it's pulling the air from and that there is minimal resistance in the flow path.
