Alternator or battery?? Ebrake light + batter light!!!
Old Aug 28, 2017 | 12:57 AM
Ottovq35's Avatar
I had my alternator and battery tested the other day and it came out that my alternator was bad but my battery is good so just recently i replaced the alternator with a new one and everything seemed fine no battery lights on my dash until after driving it for about 5 minutes the battery lights came on solid red no flickering. The next day i was driving and the car died on me while on the road, i gave it a jump boost and it started running again without any lights on my dash until later again the battery light came back on. I noticed that my dash lights starts to faintly flicker while sitting idle.
Anyone got an idea of whats going on with my G35 coupe??
Old Aug 28, 2017 | 05:36 AM
telcoman's Avatar
Veteran: Army
Defective battery, defective alternator or both.
Test the battery with a battery hydrometer, test the alternator output voltage across the battery with the engine running with a multimeter.
Telcoman
Old Aug 28, 2017 | 09:37 AM
gary c's Avatar
Welcome to the G35 Driver forums Otto! A few years ago one of the "Know it All's" here on Driver made fun of my installing gauges in my coupe. My reply was, "I can tell what's going on under my hood!" Your alternator s/b putting out 14.5 volts, if it isn't you'll have issues like you posted. Take your G back to where you purchased the new alternator and have both battery and alternator tested. Also check your battery connections, they must be very clean and snug!
Again welcome, your issues s/b easy to correct...Gary
Old Aug 28, 2017 | 10:25 AM
coffeysm's Avatar
Have your battery load tested and test the charging system again. Depending how long you were driving with a bad alternator it could have worn the battery out.
