2006 G35 Tire Help...
Old Sep 20, 2017 | 05:53 PM
mkart9999's Avatar
Hi...my son just bought an '06 G35 and is running the standard 225/40/R19 up front and 245/40/R19. I'm looking to get him some winter tires and I'm the farthest thing from an expert in tires and what options are available so I can use the existing rims.
Is it possible to run 225/40/R19s on all 4 tires? I found a set of 4 very good condition winter tires and was wondering if I can use them? What are the issues on not sticking to the standard staggered sizes?
Thanks for your help!!!
Old Sep 20, 2017 | 08:52 PM
jgonz951's Avatar
Theres really no issue running that for a winter setup. The wheels are only .5" In difference so the rears may be a little stretched but nothing too bad. However I would recommend 245 40 19 all around since theres more contact and meat on the tire. But if the ones you are looking at are worth it then I do not see a problem. Just be very careful with a RWD car in the snow.
Old Sep 20, 2017 | 10:19 PM
ScraggleRock's Avatar
Actually running the 225/40 in front and back looks really dumb. You're better off with the 245/40 all around
With 225/40 in the back, you'll be looking at almost an inch and a half of extra space between the tire and fender. Trust me, I test fitted it and it looks really ridiculous. Great acceleration tho.
Old Sep 20, 2017 | 10:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
Guys he's talking about winter tires so how they look isn't all that important here. The skinnier the tire the better it is in winter/snowy conditions so I say do it OP. Safety is your main concern and the 225/40s will do just fine.
Old Sep 21, 2017 | 09:58 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Strongly recommend picking up a set of the stock 17 or 18" rims to use as winter tires if it snows in your area. 19's with snow (even with good winter rubber) is a recipe for disaster.
Old Sep 22, 2017 | 01:06 AM
Well, I gotta look cool at all times, so my statement stands.
Old Sep 22, 2017 | 04:38 AM
Blue Dream's Avatar
lolololol, of course it does........
Old Sep 22, 2017 | 11:07 AM
gary c's Avatar
Originally Posted by ScraggleRock
Actually running the 225/40 in front and back looks really dumb. You're better off with the 245/40 all around!
I concur, when was the last time it snowed in Texas "by the sea?" A set of 17" coupe rims with 245/40 winter tires should get you thru several winters and not look like a dork! www.thetirerack.com has all their winter tires on sale, they sell at wholesale and deliver to your front door. Any wrecking yard s/b able to find those rims for you!
Gary
Old Sep 29, 2017 | 10:50 AM
Urbanengineer's Avatar
I’ve ran the winter set up on 19” wheels for four years, Ohio heavy snows. Never had a problem LOL. You should know proper tread and quality is everything.
Op you’ll be fine on those, but dedicated winter wheels would be a better option.
Old Sep 29, 2017 | 12:44 PM
gary c's Avatar
The cost difference between 19" tires and any smaller in diameter tire is major, maybe 50% less! Cost of wheels in the 17"/18" range is insignificant...Gary
