A/c question
Old Oct 26, 2017 | 10:41 AM
Dawgfan2017's Avatar
A/c question
I checked my fuses for my blower motor for the A/C in my 06 Infiniti g35 sedan. it will blow but takes for ever for it to come on and then some times it will just shut off trying to figure out what would be causing this. I was thinking it was the relay for the A/C system but cant find the right relay can anyone please help me. Thank you in advance
Old Oct 28, 2017 | 09:59 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The relay is BEHIND the fuse panel in the cabin, on my coupe it was the one closest to the firewall. You need to remove the plastic cover (not just the little access panel in it), then the two 10mm screws holding the fuse panel into place. This will give you enough room to lift the fuse panel up enough to access the relay, it's blue, there will be a couple of them but on my coupe it was the one closest to the firewall. Easy enough to figure out which one, just unplug one and see if the AC blower works or not (recommend disconnecting the battery during any electrical work).
Autozone carried the OEM relay, not just an replacement generic
osuav8r
Feb 18, 2018 07:29 PM
VettRN
Feb 4, 2003 06:30 PM
hoshtaylor
Dec 11, 2002 06:29 PM
Mr_G35
Oct 12, 2002 08:44 PM
Mr_G35
Oct 10, 2002 11:15 AM
