How to remove G35 Coupe door?
Old Nov 12, 2017 | 06:52 AM
GOAT's Avatar
G35 coupe
Exclamation How to remove G35 Coupe door?
Does anyone know how to remove the door from a V35 Coupe?
Tried searching it but all I see is the panel removal for changing the window motor .
Old Nov 12, 2017 | 11:16 AM
Edgarc6789's Avatar
Remove the front bumper
Then headlight
Remove fender liner
To remove the fender
Once fender is removed disconnect harness
Open the door and remove that thing that holds open the door
12mm and the 2 10mm on the door
Then close the door and remove the 4 12mm bolts holding the door which is heavy
Am I right? I just woke up
Old Nov 12, 2017 | 12:15 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You can leave the bumper and fender installed it you have two people to help you. I recommend rolling the window down so you can grab the door frame at the top, the door is about 150lbs with the glass installed. Remove the single bolt for the door check, remove the nuts for both hinges, lift the door away from the hinge studs slightly so you can access the door harness connector, there is a pawl and lever assembly to remove it. It's hard to see with the door installed, get a small inspection mirror to look on the backside of it and you'll see what I mean. There's also a picture in the factory service manual under "body, locks, and security".
Old Nov 13, 2017 | 06:50 AM
GOAT's Avatar
G35 coupe
Thanks...
have any pics ?
Old Nov 13, 2017 | 12:02 PM
cleric670's Avatar
BANNED!!!
Door check bolt
Harness connector snaps off, tab is on the back side.
Hinge, remove 2x nuts on upper and lower hinge.
Old Nov 15, 2017 | 12:18 AM
GOAT's Avatar
G35 coupe
Dope man...I really appreciate u both .
