Strange Transmission Noise
Old Mar 31, 2018 | 12:25 AM
g35life's Avatar
This only happens when pressing the clutch in. I don't think it's the throwout bearing. What can it be??
https://youtu.be/iNb6BluHSXU
Old Mar 31, 2018 | 09:00 AM
Blue Dream's Avatar
I drove ttrank's car solo
That's a weird sound, almost like a belt squealing. Subscribed for potential causes.
Old Mar 31, 2018 | 11:22 AM
g35life's Avatar
No idea,def not a belt . Coming from trans .
Old Apr 1, 2018 | 03:29 PM
GaryEvans's Avatar
Throw out bearing.
Old Apr 1, 2018 | 05:58 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep, throwout bearing right before it blows up.
Old Apr 1, 2018 | 08:04 PM
g35life's Avatar
not sure if its the throwout bearing...
the noise stops once you press or depress the clutch....
its only while youre engaging or disengaging the clutch..... when your foot is flat on on the ground with the clutch pressed its not noisy... or when youre off the clutch
its only when youre in that motion...
Old Apr 2, 2018 | 03:22 PM
GaryEvans's Avatar
Can't answer that but the throw out bearing is the first thing I would try. Perhaps from throw out bearing wear the arm is touching something during engagement. I'm assuming that this was not triggered by someone working on it.
g35life
Dec 8, 2017 11:09 PM
oc1959
Jun 7, 2011 03:20 PM
si_driver
Drivetrain
Nov 7, 2009 12:01 AM
