Timing chain tensioner
I have a slight grinding/clanking noise that happens at cold starts and lasts less than a second after start up. From what I understand it may be the timing chain tensioner losing pressure and since it's only a $50 part it's worth a shot.
Removing it seems easy enough but are they any tips to make sure I don't jump the timing? I plan to take off only the small cover that covers the tensioner and then removing the 2 bolts from there. Once removed, the chain will of course loosen up. I'm hoping this job can be done without taking off the entire timing cover.
Thanks in advance
Thanks in advance
vqde2004
Mar 25, 2020 11:51 AM
medianjoe
20
May 30, 2019 02:57 PM
Jbl_91762
Jan 23, 2017 09:11 PM
Hi-TechG35
19
Sep 24, 2014 09:15 PM
