Is this fixable? Engine block flange to transmission broken.
Old Apr 24, 2018 | 02:22 PM
Parturiency's Avatar
As I was replacing my transmission, the transmission bolting flange broke off. It's the little bit where the gold plate bolts to. Can this be welded back together? I realize it needs to be very straight for there to be no leaks.. , but, if it wasn't, could I put gasket maker all the way around to seal it up? Bought this car to flip and this happened and now I'm in the hole if this can't be fixed..
Old Apr 24, 2018 | 03:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's actually the upper oil pan, yes it can be taken off and replaced with a non-broken one.
Old Apr 26, 2018 | 05:28 PM
raygun's Avatar
Yes, you can have it welded. A competent welder can fix that with the engine in the car, once it's on a lift - which will require a tow, or a push start, since:
That's where the starter mounts. Having it "slightly off" isn't going to cause "leaks" as there's no fluid on either side of that. But, it needs to be straight to get the starter to engage properly.
If you decide to go that route, and it's probably going to be a LOT cheaper and less trouble than replacing parts, make sure you tell the shop, when you're shopping around, that it's an aluminum block. Welding AL vs steel requires different technique and equipment.
Replacing the upper oil pan, as @cleric670 proposed, is a pretty big PITA and stops just short of having to pull the engine. It's not impossible or particularly difficult - it's just a lot of work. Front cross-member has to come down, etc.
kenempireex
Jul 17, 2008 06:32 PM
officerdbag
Mar 25, 2008 01:55 AM
gang unit
Archived Sales
Nov 9, 2007 12:39 PM
midnightrunner
Nov 26, 2006 02:32 AM
Jellysick
Jun 12, 2006 07:00 PM
